Results 1 to 7 of 7
Thread: sunroof leaking under heavy rain
    Sep 2010
    1987 Accord Exi 160,000 kms
    Western Canada
    My sunroof started leaking yesterday, I guess it never this hard during the summer months. It's leaking from the rear, so I'm guessing the rear drain tubes are clogged. Is there write-up available on how to remedy this problem?
    Re: sunroof leaking under heavy rain
    Yes, search. I think people attached a pipe cleaner to the end of a hanger or something. Maybe use Plumbr? hahaha
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Well find the tubes and clean em out lol you don't need a write up for that haha probably just have build up dirt in there
    Frt tube located behind the lower ft kick panels
    Rr. tubes located in the truck behind the side panels
    If you have a compressor you can blow them out with air and a extension nozzle
    Sep 2010
    Western Canada
    What about the roof itself, how do you fix it from leaking?
    SE-i Sedan 5 spd
    The sunroof is not leaking, it is not made to be watertight. That's what the drains are for.
    See this post. Use a panel removing tool to take out the buttons in the trunk as a screwdriver will mess them up. You can get one at Autozone, looks like a very broad forked screwdriver that has a bend in the end.
    https://www.3geez.com/forum/showthrea...hlight=sunroof
    Learn to search. That way you can answer your questions without having to wait for people to respond. Also, on simple questions like this, where there are lots of previous posts, many people are tired of spoon-feeding, so they don't answer at all.
    Dec 2003
    Millington, TN
    Don't to crazy with the compress air, you can detach the tube from the liner outlet nozzle. A can of copressed air is more likely not detach the lines.
    You might have to pull the liner down to clean the debris, the headliner is designed to hold water until it can exit thru the outlet nozzles, which is why there are 4 of them. It is real simple, don't make it out to be a mountain of a job. Just alittle time consuming.
    Phil
  1. Should I keep her? (Image Heavy)
    By JamesJimJam in forum Classic Honda Community Chat
    Last Post: 07-31-2011, 06:59 PM
  2. Heavy Rain leaky car
    By LewZur in forum Classic Honda Community Chat
    Last Post: 01-20-2010, 02:07 PM
  3. Sunroof leaking air...
    By Bloodlust in forum Classic Honda Community Chat
    Last Post: 01-03-2004, 05:51 PM
  4. How do i stop my leaking sunroof
    By Badboy2005 in forum Classic Honda Community Chat
    Last Post: 03-15-2003, 03:11 PM
  5. Heavy ass rims, need lighter ones!!
    By Chrome_thangs in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-13-2002, 05:58 AM
