Results 1 to 6 of 6
Thread: Help it wont turn over for awhile
    Jun 2010
    88 accord lxi 4door
    Ok my problem is that my car won't turn over when I insert the key and turn it u can see the rpm go up to maybe 100 then instantley back down to zero with out turning over after doing that constently (turning the key to start the car) it'll turn over a little bit buut then shut off. But after awhile of doing that it'll finally turn over and start could it be the starter?
    Jun 2010
    Re: Help it wont turn over for awhile
    Bump....anyone? Please ? Lol
    LX User stephensimmons's Avatar
    Jan 2010
    89 Honda Accord LX-I
    summerville,south carolina
    Quote Originally Posted by va_nig_rawr View Post
    CHeck all your battery connections first. MAke sure all of them are clean and tight even the ground! And if all thats good then the starter is bad. Check the cables at the back of the starter to.
    Jun 2010
    Yeah my batter is fine so are the termanials need to check my ground though but if its none of the termanils or ground then its the starter correct?
    Jan 2010
    Yes sir sounds like it!
    LX User Xaisk's Avatar
    Feb 2010
    1989 Accord Sedan
    Oklahoma City
    I had the same issue when I was getting mine running again awhile back. It turned out to be a ground.
    The ground that connects from engine block to frame was the culprit. Take the ground wire off, file both ends down nice and clean, then file down the area where it connects to the frame. If paint or rust are on the frame it will prevent grounding.
    If that doesnt work, then take it to an auto parts store like O reilly auto or advance. They test starters for free. Starter has to be removed from the vehicle though.
  1. engine wont turn over
    By doc in forum 3geez Accords
    Last Post: 10-10-2011, 11:47 AM
  2. wtf, wont turn right??
    By 2drSE-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-29-2005, 08:32 PM
  3. need help wont turn over!!
    By 88accordalltheway in forum 3geez Accords
    Last Post: 08-17-2004, 11:03 PM
  4. Fan wont turn off
    By Scarface in forum 3geez Accords
    Last Post: 09-04-2003, 01:21 AM
  5. damn fan wont turn off... please help
    By ALTERED4 in forum 3geez Accords
    Last Post: 02-28-2003, 04:37 PM
