Having with a problem with my car rumbling/burping while idling. Especially bad when cold when it first starts up. One of the things I’ve looked at was the EFE heater. When the car is first started cold, I have no power going to the EFE heater. The relay appears to be fine. There is battery power to the relay but no control power (blue wire). The car is an 88 lx. The Honda manual shows that there is an EFE control box which goes between the ECU and the relay, with the output of the ECU being wire A4. The shop supplement manual also shows the same arrangement. Unfortunately the manual appears to be wrong. There is no wire from A4. What looks to be the situation on the car is that the ECU output of B24 controls the relay. There is no other external box. B24 has no power on it, which appears to mean that either one of the inputs to the ECU or the ECU is bad. The four inputs that I know of appear to be OK (B22 battery, B23 ignition, ignition A11, and TW sensor A7). I have replaced the ECU with another ECU from a junk yard and nothing has changed. Anyone have any ideas? Thanks for any feedback.
