Results 1 to 17 of 17
Thread: Headlights
    Headlights
    Hello,
    Need your help asap!
    My Accord LXI headlights just started opening and closing by themselves, even with the car turned off. What is the reason for this?
    Thanks!
    Re: Headlights
    its just blinking
    Re: Headlights
    its just blinking
    Back on topic.
    Unplug the switch on the dash that controls the headlight doors.
    It's probably shorting out
    Re: Headlights
    Where is the switch and what does it look like? How do I unplug the switch and what do I need to do to get it working right again?
    Thanks.
    Re: Headlights
    The three-button switch to the right of the steering wheel. Use a thin flat-head screwdriver to pop it out from the bottom, and make sure all of the connections are good. If not, replace the entire thing or just the switch for the headlights (the one furthest to the left).
    Re: Headlights
    could also be an internal failure in the motor relays and or retractor control box.
    Re: Headlights
    I'm a newbie at this. Where are the motor relays and retractor control?
    Re: Headlights
    As to the switch, I looked at the two switches, one to the left of the steering wheel, and one to the right of the steering wheel. I don't see how those come out, those look like they go into the steering column.
    Re: Headlights
    Ok, I unplugged the switch you were talking about, and the headlights stop opening and closing.
    However, if I turn on the headlights with the headlight switch to the left of the steering wheel, they start opening and closing again.
    But, if I put the headlights in high-beam mode, then they stop opening and closing.
    SEi User phrenology's Avatar
    Accord 88 LXi Coupe
    Regions Unknown
    Re: Headlights
    its just blinking
    Its the work of Satan. It requires an Exorcism. Repent now evil Honda.
    Re: Headlights
    Please include only on-topic replies. Thank you.
    Re: Headlights
    Well, it would be very on-topic to mention that a search would have gotten you less jokes and better answers. The search box is on the right side of the menu bar at the top of every page. Please make a note of using it in the future.
    https://www.3geez.com/forum/showthrea...pening+closing
    Accord 88 LXi Coupe
    Regions Unknown
    Re: Headlights
    Re: Headlights
    Actually what I described in my question is not described in a previous question. Pico, Charlie and B20A, your replies were helpful.
    Thank you.
    Jun 2010
    Originally posted by ShiRen:
    Re: Headlights
    You guys need to stay on topic. This has gone way off track.
    It's gonna be another thread filled with bs.
    Re: Headlights
    You got something wrong with your headlight wiring or the combo switch behind the steering wheel.
    If you need the headlights you can pull the fuses for the headlight motors and run them up manualy under the hood. There are knobs on both side right by the headlights.
    Have you done any wiring to the car lately like adding in fog lights ?
    Your going to have to inspect the wiring to the headlights as well as the wiring going to the combo switch.
  1. jdm headlights anyone????
    By guaynabo89 in forum 2geez Accords
    Last Post: 04-05-2009, 01:26 PM
  2. H4 Headlights
    By alanizgod in forum Interior & Exterior Care
    Last Post: 06-16-2007, 01:45 PM
  3. headlights
    By ang1699 in forum 3geez Accords
    Last Post: 01-07-2006, 09:16 AM
  4. Headlights
    By BlueBead in forum Interior & Exterior Care
    Last Post: 10-10-2005, 09:30 AM
  5. pop up headlights
    By veedubbin in forum 3geez Accords
    Last Post: 03-26-2003, 12:50 PM
