Can the inner tie rods be removed without renting a special tool and does one inner tie rod tool work with all inner tie rods?
The location makes it hard to use other tools. My next tool of choice would be a large crow foot wrench. I've seen some ppl talk on here about using a large open end wrench &/ cresent wrench to get theirs off. Some parts stores rent the inner tie rod end removal tool. If I remember right, it's somewhere around 32 mm.
everytime i've had to do rack ends, i've used a set of 12 inch vice grips with great success.
you dont need any special tools, i rented 2 different kits thinking i needed one, and none of them fit at all..
i just used an open ended wrench, cant remember the size, but make sure you put the boot back on afterwards or your rack will prematurity wear out!
if the inner tie rods are shot, you might be better off to just get a rebuilt rack and replace the entire thing. by the time you buy the tie rods, boots, etc. and go to all the trouble, you could have swapped in a rebuilt.
