Results 1 to 15 of 15
Thread: Question: Front LCA outer bushing change
    DX User 4literranger485's Avatar
    Oct 2010
    1988 Honda Accord LX
    California
    Can I change this bushing while the front LCA is still bolted to the subframe/unibody?
    Got the dreaded "bolt stuck in damper fork" and had to cut, now i need to press out the old bushing (should be easy, it's like mush in there) and then press in a new one. I do NOT want to completely remove the LCA because i'm guessing that bolt is dickered too....and i don't want to open another can of worms.
    long story short: can i press out/in the damper fork/LCA outer bushing with the LCA still attached to the car?
    Thanks in advance gentlemen!
    There are rules here!
    Re: Question: Front LCA outer bushing change
    All things are possible...
    You will probably have to spend some time finding the right tools to do it on the car. Obviously, you aren't going to be able to fit a 100 ton hydraulic press under there, so you're going to be doing it the old-fashioned way, with brute force and something like one of these:
    Honestly, if things are really corroded under there, then you will have an enormous fight on your hands, even if you have it out of the car. Having it in the car will only make things harder. Douse it real good with PB Blaster for several days beforehand and let 'er rip.
    If you can't do it, then you can always go back to pulling it out of the car.
    Good luck with that one. There are many horror stories on here about those LCA bushings.
    Oct 2010
    California
    this is honestly rediculous.
    that bushing will NOT come out of the LCA. the LCA will NOT come out of the car, the bolt will start backing out of the LCA mount to the car, but it just starts bending the mount because obviously it's just as seized as the other one.
    does everyone seriously just cut the bolts and replace the LCA? that's pretty rediculous to have to be done just to change a little halfshaft. what a poor design.
    anyone with some serious tips will be much appreciated. i know someone else has done this before, it seems like an incredibly common problem with these hunks
    cygnus x-1's Avatar
    Chicago area
    Quote Originally Posted by 4literranger485 View Post
    The design is fine, it's just that it's 20+ years old and has probably never been apart for service. Around here cars are lucky to last more than 15 years without massive rust from road salt.
    If those bolts are really seized up then it's easiest to cut them out and get new ones. With the arms out, use a torch to burn the rubber out of the bushings. It's stinky and messy but kind of fun because you get to play with fire. With the center sleeve and rubber out use a hacksaw blade to cut a slit in the outer sleeve so it loosens up enough to come out. Be careful not to cut into the arm itself though. Now the new bushings can be pressed in. They're tight so probably it will take a hydraulic press and not just pounding with a hammer.
    C|
    hammer3rd's Avatar
    Sep 2008
    2000 Powerstroke 1988 LXI sedan
    Claremont
    I found it eaiser to cut what needed to be cut then go to a pull a part and buy a entire new old part with all the bolts for 20 bucks or so. But be careful not to damage the crosmember as it is pretty cheap to buy but a lot harder to replace.
    Mike C in NC USA
    SE-i Sedan 5 spd
    I happened to walk up to a smoldering little fireball as my mechanic was burning out the rubber bushing. It gave me a start, that's for sure.
    Oct 2010
    California
    Quote Originally Posted by hammer3rd View Post
    got an LCA with bushings on the way for $20. i noticed the bolts inside the bushing sleeve are somewhat fluted (wtf over?) that just seems like the perfect way to get more moisture in and aid in corrosion
    i'm gonna put a freakin' jug of anti-seize on each bolt.
    I'm just bummed that this seemingly easy task turned into days of work, it's really making me think twice about switching out the struts to tokico's and drop springs
    You so realize how old that car is, right? Do you live in a high humidity, area, or close to the ocean? Ive replaced LCA's on 4 different 3Geez here in Texas, and not once had that problem. Honda can't protect against everything, the fact that a 20+ year old car still has the factory bushings is rather amazing!
    Oct 2010
    California
    southern california, mojave desert. it's quite dry
    stock bushings....amazing, or insane! one of the two. those things we're probably shot over 100k miles ago
    That is strange, would not expect very much rust in the Mojave desert . At least the parts are cheap!
    cygnus x-1's Avatar
    Chicago area
    The fluted bolts are odd. Not sure what the purpose was for those.
    And yeah, anti-seize is our savior. Once you get it apart the first time, it's easy from then on.
    C|
    Oct 2010
    California
    way to be a "glass half full" guy Got the LCA with bushings on ebay for $20. should arrive tomorrow, and hopefully i'll be driving the beast this weekend. I'm sick of putting gas in my truck already
    Oct 2010
    California
    Alright, got this thing back together last friday when my arm arrived. WOW what a royal PITA
    Now it appears to be leaking a bit of gear oil, it does not appear to be coming out of the axle seal area.
    My question is: I filled the manual trans with the left side of the vehicle jacked up, could this have possibly allowed me to overfill the trans? and If so, is there some sort of breather hole that will stop peeing out synchromesh when the level is appropriate?
    thanks in advance gentleman!
    You probably did overfill, but there is a breather hose on the trans. Make sure that it is what is leaking and not something else. You don't want to drain the thing dry and burn it up.
    Oct 2010
    California
    i'm keeping an eye on it, it's not a ton of fluid under there. i'll notice if 2.5 quarts comes out
    thanks for the answer/reply man!
  1. Front suspension bushing overhaul
    By codyJDM in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-25-2012, 06:46 PM
  2. How to: Change Outer Tie Rod Ends (for dummies)
    By Toneloc5145 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-13-2008, 08:44 PM
  3. Front Control Arm Bushing replacement
    By '89AccordLX(Rus) in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-01-2006, 06:38 AM
  4. Front lower arm bushing choice
    Last Post: 03-29-2005, 06:39 PM
  5. Sway bar bushing part number change
    By Sabz5150 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-01-2004, 12:07 AM
