Just some pics now. I will up date with the specs and details later.
The pistons. Custom made diamond pistons. The tops of the pistons are ceramic coated and the sides are moly coated.
The block. Bored to 3.285 in / 83.439 mm
The Pistons, rods, and crank installed. The rods are eagle H beams.
The only snag i ran into. I had a rod bolt that never reached the proper torque of 28 ft-lbs and ended up looking like this. Called arp for a replacement and they said that they had some problems with these bolts on the eagle rods a few years ago. I've had the rods sitting for a couple of years. The one replacement bolt was $8.
