Results 1 to 13 of 13
Thread: Motor Swap with europe. Accord AeroDeck
    DX User flaxmo's Avatar
    Oct 2010
    98 Accord Aerodeck CA5
    Leipzig, Germany
    Hello Guys,
    my name is Max, i am from germany and now i am owner of an 89 Accord Aerodeck. The Accord at first, had an A20A1 Engine which was swapped by A20A3 sohc 12V EFI Motor with 85 or 75 Kw, i dont know exactly. Now i want to swap again but not with A20 block. I have the chance to get a B20A8 dohc 16V Motor in good condition and i want to know if this is possible without many or expensive modifications. Does anybody know?
    I hope my english is ok:-)
    Thanks and greetz
    Nafs Asdf's Avatar
    Feb 2008
    Finland
    Re: Motor Swap with europe. Accord AeroDeck
    Welcome
    As long as you get the ECU, gearbox and axles with the B20A8 there shouldn't be anything to it other than just dropping the new engine in.
    Oct 2010
    Leipzig, Germany
    Thank you.
    With Axles you mean the parts from motor to wheels right? are they stronger or?
    ok and the gearbox? is it part directly connected to the engine? i have here some pictures of the block:
    i am not an mechanican, i will only buy, the intake will be done by my mechanican:-)
    edit: i need 5 posts to show you the pics, i will upload later:-)
    carotman's Avatar
    Montreal South Shore
    The axle is this part:
    The transmission is the gear box.
    I need these parts!
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Yes, B20a2 or B20a8 is a direct fit. You can use two passenger side axles from A20a, because they are the same.
    And I believe the Aerodeck were only A20a4 option in Europe. A20a3 was US option with EGR and Cat. Early A20a4 before 88 was non Cat.
    And Welcome here..
    My Build Thread
    Nafs Asdf's Avatar
    Feb 2008
    Finland
    Quote Originally Posted by Tomisimo View Post
    And Welcome here..
    You'd still need the half-shaft from the B20A tho, right?
    I'm pretty certain some parts of Europe had the A20A3 too, all depends on the local emission laws. In Finland we never got any 3Gs with emission components (my B20A8 is from Switzerland), I think the cat requirement came sometime 89 or 90 here. But in other parts of Europe they came earlier.
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    yes in general Europe went for the emission control in 87. thus all cars after 87 sud be equipped with cat. I'm lucky, my car is a import to, from Belgium. because of that there literally no info on my car in Vehicle Registration Paper. Meaning I can do allot wit it. and its a 87, so no cat.
    My Build Thread
    LXi User bryan6732's Avatar
    Aug 2008
    The Netherlands
    Welcome
    And Welcome here..
    Hmm you said only B20a2 and B20a8 are direct fit... Thought all B20a engines were the same from the outside. So how about JDM B20a ??
    Nafs Asdf's Avatar
    Feb 2008
    Finland
    The jdm b20a is the same too, the only significant difference being the ignition stuff and ecu. The jdm one has electronic ignition advance while edm models are vacuum advance.
    The b20's that will not fit are the ones out of 88-91 preludes.
    Aug 2008
    The Netherlands
    Right. Thanks for the info..
    And the lude B20s don't fit because of the angle right??
    Nafs Asdf's Avatar
    Feb 2008
    Finland
    Correct.
    Oct 2010
    Leipzig, Germany
    Thanks for information.
    Are there other possible motorblocks for example F20 or Heads like Z3 (because i can get an B20Z3) or is it to much?
    Oct 2010
    Leipzig, Germany
    Anybody know which axles are also possible? Maybe Civic or Prelude BA4?
  1. 86 accord motor swap or mod
    By my_project_86 in forum Newbie Introductions
    Last Post: 03-26-2012, 09:15 PM
  2. 89 accord 2nd motor swap help
    By petey882 in forum 3geez Accords
    Last Post: 05-08-2009, 06:53 AM
  3. What is the best motor swap for an 85 accord??????
    By Shootinfor6's in forum 2geez Accords
    Last Post: 09-09-2006, 06:14 PM
  4. any one of a motor to swap into an 89 accord lxi
    By k-butta in forum Performance
    Last Post: 09-17-2003, 09:36 AM
  5. Fixing My Accord with swap 86k a20a3 motor
    By Tref_LXI in forum 3geez Accords
    Last Post: 03-11-2003, 10:17 AM
