Results 1 to 2 of 2
Thread: No more shaking when braking!
    Jan 2010
    86' Accord Lxi
    Thank god it is finally gone. 2 days ago I put new rotors and pads on the front, seemed to help a little but didn't do the trick so I bought new shoes for the rear and put them on.
    Turns out my wheel cylinder was bad. Threw a new one in bled the brakes and the shake is gone, it finally stops like a "normal" car again! But I also swapped my throttle body hoping to get my idle down to 750 but now it's like 1500
    Idk what the deal is everything is hooked up right, I read a thread saying it might be the fast idle valve i'll try turning that all the way in and if that doesn't work got to swap my old one back in.
    1986 Accord Lxi- Auto,Blue,155k
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Re: No more shaking when braking!
    to get your idle speed down you need to clean idle valve. its filthy, not the throttle body.
    Good luck
    My Build Thread
  1. violent shaking while braking.
    By honda crew in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-26-2012, 04:19 PM
  2. Front end shaking, when BRAKING
    By nswst8 in forum 3geez Accords
    Last Post: 10-18-2004, 03:35 PM
  3. Shaking
    By Janiel in forum 3geez Accords
    Last Post: 05-13-2003, 10:42 AM
  4. i want better braking
    By od2681 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-20-2003, 10:49 PM
  5. steerong wheel shaking when braking
    By ACCORD EX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-26-2002, 02:37 AM
