Results 1 to 4 of 4
Thread: Replacing Dampers/Shocks... what bushings?
    Jun 2009
    Good grief, there are a lot of "rubber" parts in these suspensions. A couple years back, I replaced both the UCA and LCA on both sides in the front. New sway bar end links. Leaving only the sway bar bushings, the "strut rod bushing"?? and all the bushings on the shocks.
    I'm going to install the KYB GR2 units at all four corners, and am having a hard time trying to figure out what bushings to purchase to go along with the shocks. The nomenclature for the different bushings is confusing. Every site describes the bushings with different "names" Anyone know what bushings I'm in need of? Seems I need upper and lower bushings for each shock, would that be correct?
    1988 Accord LX-i, A/T, 4-Door, Gold Ext, Maroon Int, 225k on clock
    1999 Ford F-250 XLT SC, PSD, 4x4, vegetable converted beast!
    car6289's Avatar
    Jun 2002
    1989 Honda Accord LX , 2009 Honda Ridgeline & 2005 Honda Civic (1987 Accord LX - RIP)
    Abbotsford, B.C., Canada
    Re: Replacing Dampers/Shocks... what bushings?
    Strut rod bushing, I've heard of some people calling the radius rod the strut rod. The radius rods on our cars coincidentally has a steel bushing that centers the radius rod within two rubber bushings. I think in your case it is the steel sleeve bushing that goes over the shock piston and centers the shock piston between the two upper rubbers in the top hat. It is #15 in the picture. You may need one for each shock due to the old ones being seized with rust to your old shocks. You may also want to replace the two rubbers per shock #7 depending on their condition and your budget.
    The picture is of the front only and according to hondaautomotiveparts.com the rear collars (Honda's name for these bushings) are a different part number than the front collars.
    Jun 2009
    Thank you... see what I mean about the naming conventions the different parts houses have for these things. I thought those were the parts, so I'll go with them.
    On the front the lower bushing is part of the LCA, and was part of the new unit so I should be good on that, but out back, I think I'll spring for what ever they call the lower bushing for the shock
    car6289's Avatar
    Jun 2002
    Quote Originally Posted by CPUNeck View Post
    Although you previously replaced your LCA assemblies, both bushings within each LCA are individually replaceable.
    Good call to replace the rear lower bushings. 20+ years of service is long life for a bonded rubber and steel part. Yes, there are a lot of "rubber" parts in the suspension of our cars. If these rubber parts have not been recently replaced, they are probably due to be.
  1. Dampers (a.k.a. shocks) + What's Available
    By AZmike in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-02-2020, 06:00 AM
  2. Replacing the stock Front sway bar End Link bushings.
    By firefighterwhite89 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-04-2012, 06:11 PM
  3. Replacing Ctrl Arm Bushings?
    By vteckiller in forum 3geez Accords
    Last Post: 02-21-2012, 05:04 PM
  4. replacing front lower control arm bushings
    By lamontlamont in forum 3geez Accords
    Last Post: 10-24-2005, 01:55 PM
  5. found a how-to for replacing the control arm bushings
    By maka_RTH in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-23-2004, 12:25 PM
