so my car quit on me hit the key and nothing, so i jump start it. seems like the battery is real low, wipers move very slowly, and lights dim. stop at a red light dies again, so i get a boost and drive home with out stopping or the car would die. i charge up another battery and put in it. everything seemed to work fine. later that night car dies again while driving. My ground cable connection was kinda loose so i put a new end on it. Still had the problem. I checked voltage with out car running i had about 11.8 then got the car running and only had like 12 something, so i assume the alternator is bad, i buy another one. put it in take the car for a drive come home shut it off. hit the key. nothing again. switch batterys again get it running test volts when running again and i'm still only getting a little over 13.
I cant figure it out. I read if there is a short you can check by putting a test light from the ground cable to the ground post and if there is a short the bulb will light. so i tried this and it did not light.
It seems to me like the alternator is charging but the full charge is not making it to the battery, any ideas?
