Originally Posted by
lostforawhile
you don't need the lubrication, those bronze bushings have the oil impregnated in the bushing, they last for a very long time, and the ends of the shafts are running in Timken bearings, those timkens use high temp grease just like a wheel bearings, and are easy to replace. I've worked with both kinds of bearings for years, this is an adaptation of the valves on the wankel engine, the seals were the main problem, but Mazda came up with new ones. this is probably a similar technology
