Results 1 to 9 of 9
Thread: Retarded Temperature! HELP!!
    DX User JDMPrelude23's Avatar
    Nov 2010
    Bronx, NY
    I have an 89 accord lxi... I was leavin this Mornin to work and I noticed as my car was warming up that it was takin pretty long to warm up. So I left anyways cuz I was runnin late. As I got like 3 blocks up I noticed my temperature gauge is still on Cold. So wen I came to a red light it slowly went up maybe a few centimeters and then wen I started Drivin it slowly went bak to Cold. Stop at a red light and did the same thing... Got on the highway and it stood on cold until I got off the exit and got to a red light... Idk wat the hell is goin on, any ideas???????!!!??
    Facebook me= http://www.facebook.com/#!/profile.p...00000082137883
    R.I.P.= 94 Honda Prelude SI H23a
    89 Honda Accord LX-i A20
    LX User Xaisk's Avatar
    Feb 2010
    1989 Accord Sedan
    Oklahoma City
    Re: Retarded Temperature! HELP!!
    When did you last replace the temp sensor? It might be old and worn.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    I'd check the temp. of the radiator hoses on top & bottom first after it gets to operating temp. & then check back with us.
    SE-i Sedan 5 spd
    Were you getting hot air from the heater? If you weren't, probably the thermostat is stuck open. The thermostat is a temperature-controlled valve that directs the coolant through the radiator, or keeps it cycling through the block only. If it sticks open, particularly when it's cold out, the coolant takes a long time to get warm because it's going through the radiator.
    If the heater is blowing hot air, that means your coolant is hot as it should be, and a sensor is probably bad.
    I'd bet on the thermostat. It's not a hard fix, and much better that it sticks open rather than closed, because if it sticks closed you can overheat quickly.
    x2 on the thermostat.
    car6289's Avatar
    Jun 2002
    1989 Honda Accord LX , 2009 Honda Ridgeline & 2005 Honda Civic (1987 Accord LX - RIP)
    Abbotsford, B.C., Canada
    Antifreeze low?
    Learn from the mistakes of others. You'll not live long enough to make them all yourself.
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    X3 on the thermostat, also the temp sensor could be lazy and not reading correctly.
    3Geez resident body man
    Owner of Wreck-less auto body
    SE-i Sedan 5 spd
    If your thermostat is shot, it's probably messed up from gunk in the coolant. How does the coolant look? Rusty? You should probably flush the system and replace with fresh antifreeze. Hint: buy Peak or whatever coolant is dark colored, so you can see the level in the overflow bottle better. You are checking the level in the overflow bottle aren't you? And while you're at it, how are the hoses?
    Fluid management is the number one job in an old car.
    Nov 2010
    Bronx, NY
    Thankz for ya feedback... For some reason it only did it that 1 day.. but i aint takin no chances, i havent checked the thermostat but ima change it anywayz... The dude that had the car before me used water for like the whole summer so like it was pretty brown and rusty in the radiator,. i started usin coolant tho so its gettin alil better... And the temp sensor ima buy a new one too... the car is an 89 so i kno i have to make new alot of things due to its age....... ill keep ya posted!
  1. engine temperature sensor and coolant temperature sensor
    Last Post: 03-29-2008, 02:16 PM
  2. Help My 3g Went Retarded!!
    By Bglad420 in forum 3geez Accords
    Last Post: 10-08-2005, 09:43 PM
  3. retarded speedo
    By $mokenB'$ in forum 3geez Accords
    Last Post: 02-20-2004, 07:21 AM
  4. retarded Thermostat!
    By Immeraufdemhund in forum 3geez Accords
    Last Post: 06-23-2003, 09:45 AM
