Results 1 to 6 of 6
Thread: Odd noise
    LXi User CzEcHy's Avatar
    Jul 2008
    89 Accord LXI
    Gulf Breeze, Florida
    Odd noise
    Dunno if anybody else has this problem, but I have an odd clicking type noise under HEAVY acceleration. (starting at 0)
    It's coming from the left side of the car either in the engine bay near the belts, or the near the left wheel...
    The CV axles are both brand new, 2 months old.
    Belts are all new, waterpump, alternator all less than a year old.
    It's only under acceleration involving over 4500rpm.
    It's also carburated and an automatic, but the tranny is on the other side so.....
    I think it's like a clicking noise, but it really isn't, hard to describe. Maybe like a metal on metal scraping really fast.
    Re: Odd noise
    need to hear it really...
    but here are some thoughts...
    I hope youre using good oil like castrol gtx 20w50w
    Look under the hood surface to see if anything is contacting it when the motor lifts..
    Look at your timing belt while the engine is running, focus on the longest stretch between pulleys to see if it jumping or flexing excessively
    Check the crank pulley bolt for tightness
    Look at the CV axles where they go into the hub, make sure they have no dimples on the dust shiield that could contact stationary parts.
    Inspect ac idler pulley bearing
    Look at downpipe riser flange bolts, where it bolts to bracket on block.
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    Re: Odd noise
    20w50w??
    owners manual says 10w40
    is there something i need to know about different oil?
    Re: Odd noise
    20w50w??
    they are in florida so it's warm most of the year, not recommended for temps below 50 deg. and yes it works quite well on high mileage motors made before 1995 or so.
    Back to the noise, may wanna check the alternator main swivel bolt too, the 14mm one. Radial type vibrations can make some pretty strange sounds.
    car6289's Avatar
    Jun 2002
    1989 Honda Accord LX , 2009 Honda Ridgeline & 2005 Honda Civic (1987 Accord LX - RIP)
    Abbotsford, B.C., Canada
    Re: Odd noise
    Could you possibly post a sound bite, video optional, on youtube? Under your present circumstances the picture isn't worth any words.
    Learn from the mistakes of others. You'll not live long enough to make them all yourself.
    Jul 2008
    89 Accord LXI
    Re: Odd noise
    Yes I will try and get a video tomorrow.
    And I use 10w-30 Castrol GTX high mileage.
    It's also, only when the wheels spin I believe. At idle if you rev high no noise.
    Hope that narrows it down?
  1. Noise
    By DBMaster in forum Classic Honda Community Chat
    Last Post: 10-28-2009, 05:56 AM
  2. Weber DGV Noise
    By Razor in forum Carburetor Tech
    Last Post: 04-18-2005, 08:12 PM
  3. noise under braking
    By b8er in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-29-2004, 03:09 PM
  4. Wierd Noise...
    By AccordAddict in forum 3geez Accords
    Last Post: 10-16-2004, 11:20 PM
  5. odd noise
    By 87accordlx in forum 3geez Accords
    Last Post: 02-25-2003, 12:40 PM
