Results 1 to 10 of 10
Thread: High idle,brakes, power steering
    DX User Jon20683's Avatar
    Nov 2010
    1989 Accord Dx
    MASSACHUSETTS
    alright so my girlfriend bought an accord 89 dx carb obviously im new to this whole honda small mtor thing (no offense just use to chevy,dodge stuff)
    anways shes got a couple issues and she doesnt get it on the road for about a month or to so i want to cover this stuff now
    1. so she has this high idle when she first starts it and ive used the search and from what you guys say thats normal so ill take your word for it for now
    2. for some reason when shes just doing small turns like backing up or foward her steering goes in and out which i believe is just the pump which aint to bad but i just want some opinions just incase
    3. when she was driving the car home she said that when she was driving that when the car would try to come out of first gear its an auto by the way
    when she was coming out of first gear into second she said she has to let off the gas and then it goes in but it kinda nudges the car foward once agian opinions
    4. and when she hits the brakes when idleing her cars seems to almost bogg out and stall but from what ive searched its the check valce on the brake booster hose
    besides that does anyone make an intake maybe a decent exhaust?
    its her daily driver but if im gonna be fixing it im gonna have some fun with it
    and wats everyone doing for apperance stuff ??
    thanks
    Girlfriends DD: 1989 Accord dx Carb 109,xxx
    Mine: 1996 Grand Cherokee Limited v8 with some goodies
    Re: High idle,brakes, power steering
    I would try a good WD40 of all carb linkages and check for any sucked together vacuum hoses or leaking vaccum. That would produce all of those symtoms. If the car is stuck on fast idle (choke cycle) then it will also hold the transmission throttle valve cable up which would produce different shift points.
    And when the car is cold, yes when you mash the brakes you will get a vacuum surge so vacuum operated things involving the carb will act differently. I wouldnt repl check valve quite yet.
    Intakes, well those are mostly fabircated around here for the carb cars. I think you can use a 88 or so Civic breather and make something better with it.
    I recommend doing a 32/36 weber swap though which eliminates 99% of all the mystery junk under the hood!
    Quote Originally Posted by Jon20683 View Post
    I would start with some carb cleaner and then some minor adjustment. How high is it?
    I'm not sure how far gone it is, but you might be able to smooth it out with a few oil changes. Start by flushing all the old PS fluid and refilling with fresh fluid. It will turn black again in about 2 minutes, so flush again. Repeat a few times until it gets better. ONLY USE HONDA PS FLUID!!! If you don't, all the rack seals will dissolve and you'll have a big mess.
    That is probably just dirty oil. I would start with a flush.
    It sounds like, if you haven't already, a good tune up and some general TLC is in order. A lot of strange symptoms can come from simple neglect.
    Nov 2010
    1989 Accord Dx
    MASSACHUSETTS
    i took some carb cleaner the first day i looked at it
    she starts the car and the idle will gradually go up to about 2500 rpms then after a while of leaving it alone ill hit the gas and itll go down to about 1000 or so depending how long i let it sit for
    defineitly on the tune up id do that even if it was a month old just to make me feel better about the car
    snooz you said the oil you mean tranny fluid or actual oil? how do you check the tranny fluid in theses things just like regalr cars ?? running in neatral??
    i dunno about the power steering ill try the flush as its blacker than black as it is but i dont know if thatll fix it
    Nov 2010
    1989 Accord Dx
    MASSACHUSETTS
    oh and or the intake got any pics so i know what im looking foward to thanks
    https://www.3geez.com/forum/showthread.php?t=38108
    ...also a few other threads you may find pretty interesting in the FAQ section and How to section, actually better how to's in the FAQ if you ask me....
    There is the flipped lid mod too that is no cost involved.
    Nov 2010
    1989 Accord Dx
    MASSACHUSETTS
    ok so she got her accord on the road yesterday replaced the black air filter, that shit was disgusting
    havent touched the power steering yet but im pretty sure its the fluid it only does the partial turn when either in park or turning whil moving very slowly my jeep was like that and i replaced the fluid because i was doing every fluid and it stopped accidentally
    defenitly replacing the check valve i pretty sure its a dealer only part so ill go check that out and i read up alot on this site and found that her fast idle valve might need a cleaning and this is cuasing her rpms to go higher than usual and cuasing her shifts to be harder which is common sense.
    ill report back thanks guys
    Nov 2010
    1989 Accord Dx
    MASSACHUSETTS
    so just thought id update this a little for some extra help so shes had it for a while now i replaced her spark plugs/wires cap rotor grabbed 5 or six check valves from the junkyard and found a couple good ones so her brakes are fine her steering is stil kinda working on it just havent had time to look at it to bussy building the jeep anways how can i completely flush her antifreeze i did the whole drain screw thing for 2 hours and the antifreeze is still pretty rusty in her radiator.. should i just unscrew the bleeder and sit there with water till its clear???
    still trying to figure out her tranny the fluid looks fine but still acts funny
    Nov 2006
    88 DX 5spd sedan 176Kmiles, 1 owner, stock. (Sold 10/18)
    The power steering could be the belt slipping. Mine did that (when wet) until I replaced and tightened the belt. Always good to check the easy stuff first....
    There is supposedly a block drain bolt behind the exhaust manifold. Flushing is also good, but won't get it all. At least not the first few times. I finally got rid of my rusty coolant when I had replaced just about every part in the cooling system. The heater core is still original, but that's it.
    Have you adjusted the TV cable for the trans yet?
    Glad to hear the car is running better.
  1. 87 lx high pressure power steering hose
    By SFCA1987lx in forum 3geez Accords
    Last Post: 08-28-2008, 06:28 AM
  2. Good lord power steering sucks power!
    By 87DXHatch in forum Classic Honda Community Chat
    Last Post: 08-30-2005, 05:20 AM
  3. Weber Carb - cold idle fine, warm idle too high - help?
    By it's paid for in forum Carburetor Tech
    Last Post: 02-21-2004, 09:11 PM
  4. High Speed Steering Wheel Wobbling
    By hkplayer in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-11-2004, 07:24 AM
  5. power gained from removing power steering?
    By Mantis88LX in forum Performance
    Last Post: 04-10-2003, 06:50 AM
