Results 1 to 6 of 6
Thread: Running rough
    May 2008
    los angeles
    Running rough
    as the title says.... my coupes running rough.... this is happening alot now...
    ill drive then my idle jumps up to 2k and stays there.. no jumpy idle.. at the same time when i press the gas it has a delayed response and wants to die.. when im driving and i get into the gas it jerks once then goes... any ideas guys? shes full of coolant so it cant be that... i have a feeling it could be TPS or ECT.... help yeah? its my only transportation and i wanna get this fixed asap
    EDIT: forgot to add... intermittently when i push the clutch in and let off the gas... rpms go to like pretty much 0 then jump back up to 2k...
    -Tom
    1988 4 Door Lx-i 5-speed
    364,XXX and counting :]
    Re: Running rough
    Any codes?
    I think even the tps would give a code.
    Take a look at the tps cable/spring etc. Look for something mechanical in that area.
    Re: Running rough
    When was your last tune up? What kind of gas are you running? Have you checked the timing? Checked for vacuum leaks? I'd start with a bottle of injector cleaner and a good throttle body cleaning.
    May 2008
    los angeles
    Re: Running rough
    im suspecting the tps because a couple of times when it would start it would just sputter and rpms wouldnt go up unless i feather the gas alot... but she hasnt been tuned up in a while... so i figure that contributes to the problem... but being an unemployed college student its rather hard... but i have some financial aid coming in soon so im going to dump 2000$ into her and get her all fixed up... but my under dash wiring harness is messed up and it throws a code for map sensor but the map is fine and the car runs fine with that map code... so i gotta replace the under dash harness... i dont wanna replace the computer til i fix the harness problem just incase its tripping out the computer...
    does anyone have the wiring diagram for the map circuit? i wanna trace it and see if i see any opens in that particular circuit... and also if there is any related circuits that would cause the similar code
    -Tom
    Re: Running rough
    Quote Originally Posted by 1987AccordLx-i View Post
    LOL. Your problems are always so weird. When I posted, I knew I wouldn't be anywhere close to right. Anyway, PM me your email address and I'll send you the Honda Electrical Troubleshooting Manual. It's for the '89s, but you should be able to use it for yours.
    May 2008
    los angeles
    Re: Running rough
    alright doc ill pm you
    -Tom
  1. Rough running
    By sloweddi in forum EFI Tech
    Last Post: 10-13-2012, 05:14 AM
  2. Car running rough, any suggestions?
    By 87BLUELX-i in forum EFI Tech
    Last Post: 10-11-2010, 02:51 PM
  3. 89 Accord running rough
    By paulwwww in forum 3geez Accords
    Last Post: 01-02-2010, 03:48 PM
  4. Running Rough...
    By AD9SloAccrd in forum 3geez Accords
    Last Post: 01-30-2005, 03:20 PM
  5. Running rough!
    By bambamky in forum 3geez Accords
    Last Post: 05-21-2003, 10:56 AM
