Selling my 89 LX automatic with 87,000 original miles on it. Many things where replaced on it during the 2 years I owned it. The entire cooling system for the car (Radiator, both fans, every coolant line) was replaced. There is a new battery, both fuel filters are new, new tires, new alternator, new exhaust from the cat back, new silver star headlights, new carburetor base gasket and block that the carb sits on, and new oil pressure sending unit. There are a few minor things wrong too. The speedometer stopped working, so the odometer also stopped working, there is an indicated 83,261 miles but there is about 87,000 on it now. There is a power steering fluid leak, and one of the belts under the hood needs to be tightened, so under acceleration sometimes there is a squeal. Last thing wrong is, when i replaced the oil pressure sender the wire attached to it was all corroded, so it makes contact but its a shotty connection so the oil pressure light will occasionally come on. Other than that, it is a solid running car. Looking for 1,500, message me if interested in it.
