Results 1 to 12 of 12
Thread: Problem in 2nd gear
    DX User RandyAM's Avatar
    Nov 2010
    1988 Honda Accord EXi
    British Columbia
    Problem in 2nd gear
    Saw the post about some dude having problems getting into 5th gear, and i just remembered, my second gear has been acting up, and its pissing me off.
    I'll be driving along, go to down shift into second, and it'll do that horrible *grind* *clunk* sound. And if im shifting up fast, i may as well just double clutch it, and go from First to third, cuz it does the same thing.
    the clutch is original, has 204,965kms on it (put 1000kms in the first month of me having it, thats why i know :P )
    Time for a new clutch, or trans or both? my buddy has a trans from an 86 prelude that he'll give me if need be.
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Re: Problem in 2nd gear
    That tranny should work but, I'd check the fluid first? kinda fluid is in it?
    might just be the throw out bearing. Does it shimmy went taking off?
    sounds like a clutch adjustment would be a good place to start, it is not disenguaging enough possibly when you mash the pedal down
    Nov 2010
    British Columbia
    yeah, if i have the revs too low, the car will rumble in first gear until i get it up past 1500 revs
    where's the MTF go???????
    anybody got a picture they can show me with or something?
    Nov 2010
    British Columbia
    ok so i changed my MTF, and its still kind of clunking and grinding into second.
    any other ideas?
    A20A3 5spd Manual Trans
    208,000kms + Original everything
    Rebuild.
    Nov 2010
    British Columbia
    or replace. my buddy has a trans from an 86 prelude, would that work?
    Quote Originally Posted by RandyAM View Post
    As long as it's from a Prelude SI (A20A3/A4) you'll be fine
    Nov 2010
    British Columbia
    carbed motor trans and EFI motor trans are different???
    Vanilla Sky's Avatar
    1999 Penalty Box
    The final drive is different between the carbed Accord and the EFI Accord. The EFI motor has a shorter final drive, making the car a bit faster on takeoff.
    Nov 2010
    British Columbia
    ok, i'll ask my buddy and see if he knows what motor it was pulled from
    yeah if its a carbed car the flywheel and clutch would have to be from the prelude since its a bit smaller
  1. accord lxi idle problem and start problem
    By sonusa in forum EFI Tech
    Last Post: 08-21-2006, 09:05 PM
  2. Replies: 7
    Last Post: 08-11-2005, 04:17 PM
  3. Whats wrong with my car? hesitation problem & starting problem!
    By gsus in forum Classic Honda Community Chat
    Last Post: 08-11-2005, 08:04 AM
  4. Exhaust problem? ( Auto Trans Problem )
    By Jay's89Lxi in forum 3geez Accords
    Last Post: 01-18-2005, 04:24 PM
  5. Cold car accelerating problem and also a temp problem
    By chiller670 in forum 3geez Accords
    Last Post: 12-23-2003, 08:23 PM
