Originally Posted by
w261w261
The sticking ignition key means your ignition lock is telling you it is on its way to failure. Either rebuild it, which might be beyond your skill level at the moment, or get a new one, or grab one from the JY. You may have to pay someone to put it in, or search on here for how to do it. Eventually, you won't be able to get the key out at all or it will fail in another way....whatever, you don't want to have something go wrong with it just when it's most inconvenient.
Buy a decent multi-meter at Radio Shack, about $20. With a freshly charged battery with the motor off, you should measure about 12.0-12.8 volts across the terminals. With the motor on, it should be 13.5+ across the terminals. If it's unchanged, it means the alternator is not charging. The dash light being on means that the system has detected a low voltage situation.
You probably need a new alternator.
