Results 1 to 16 of 16
Thread: stuck bolt
    DX User rocketman's Avatar
    May 2006
    pocono mountains, pennsylvania, USA
    stuck bolt
    Hey Folks! Another question . . . what's your best trick for removing a stuck bolt? A few weeks ago I posted about the tranny in my '89 Accord (5 speed manual). Your posts WORKED for me! Changed fluid to Honda MTF, problem fixed. I decided to do my Mom a favor and change her tranny fluid ('90 Accord 5 speed, only 150k) and I can't get the fill bolt out. I drained the old stuff and now I can't budge the 17 mm fill bolt. Any ideas? Yeah . . it's rounded . . . and I doused it with penetrating oil . . . I tried a vice-grip on it (limited access) . . . broke a socket on it. Guess the oil was in from the factory . . . 20 years? Don't know, she got it used and drives only a few thousand a year. Any ideas? Rocketman
    May 2006
    Re: stuck bolt
    BTW . . . I was doing a normal oil/filter for her and decided to do her a favor with the tranny fluid change . . . go figure, now it's stuck in my garage and I gave her my '89 to drive (custom wheels, front air dam, custom exhaust with chrome tip, etc.) and she's bitchin' about the noise it makes! Help!
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: stuck bolt
    Get an extractor. Or you can try to smash a 16mm socket on there, but the extractor is probably your best bet.
    '89 SE-i Coupe
    Awaiting Garage
    May 2006
    Re: stuck bolt
    2-dr SEi . . . I'm not familiar with the term or tool "extractor". What is it? Where can I get one? Thanks for you reply! Rocketman
    2drSE-i's Avatar
    Oklahoma City
    Re: stuck bolt
    http://www.google.com/products/catal...d=0CCMQ8wIwAg#
    You should be able to get them at Sears, maybe lowes or home depot too.
    '89 SE-i Coupe
    Awaiting Garage
    Ichiban's Avatar
    North of You.
    Re: stuck bolt
    I've got a set of the mastercraft versions of that. Generally work well, provided that the bolt isn't too stuck in there. They tend to work best when you can beat them on with a hammer, but it sounds like you don't have the room for that.
    May have to locate someone with a portable welder and weld on a nut to the head of that bolt. Not only does it give you new wrench flats to grab on to, but the welding actually shrinks the bolt slightly and makes it easier to remove.
    Good Luck.
    ICHIBAN!
    "Now, even more better!"
    Re: stuck bolt
    Do you have a 6 point 17mm socket? Try taping that on using a breaker bar and a cheater bar. I don't think you can get at it with an Impact driver at least on a 3g. Impacts vibration sometimes knock a bolt loose. Heating it with a propane torch until the penetrating oil smokes also.
    Other thing you can try is an adjustable wrench on the good sides of the bolt if you can find any.
    May 2006
    Re: stuck bolt
    Thanks guys! I'm on my way to Sears! Rocketman
    SE-i Sedan 5 spd
    Re: stuck bolt
    Sears sells a set of extractors for close to 40 or 50 bucks, but they're good quality. While you're there, get a breaker bar, referred to in a previous post. Thats a long (30" or 3') socket bar with a 1/2" fitting on the end. Put that into the extractor socket, and that bolt WILL come out.
    carotman's Avatar
    Montreal South Shore
    Re: stuck bolt
    Don't bother with the fill hole.
    Make sure the thing is really empty.
    Remove the Vehicle Speed Sensor (vss) and add 2L from the top of the transmission.
    May 2006
    Re: stuck bolt
    Can you post a picture of the VSS? I'm not certain of where that is or what it looks like. The VSS isn't in my Haynes. Thanks so much. Nothing has worked so far, just busted knuckles! Rocketman
    carotman's Avatar
    Re: stuck bolt
    Number 3 in the picture. Just follow the speedometer cable and it'll get you there.
    Remove bolt #10 and it should come out.
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: stuck bolt
    May 2006
    Re: stuck bolt
    Thanks Carotman! I'll give that a try tomorrow. I know where the speedo cable is . . . the picture looks like the cable plugs into the VSS . . . and the VSS looks like it comes out with one bolt, only goes back one way, right? So I fill through the hole where the VSS goes? Thanks again! Rocketman
    carotman's Avatar
    Re: stuck bolt
    Yup, the cable plugs into the vss and only 1 bolt holds it down.
    It makes filling up the transmission a lot easier since you can use a regular funnel.
    Re: stuck bolt
  1. oil pan stuck
    By likewtf in forum 3geez Accords
    Last Post: 01-30-2012, 07:23 PM
  2. Rear Struts... bottom bolt stuck.
    By -$MOKIN- in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-02-2009, 03:37 PM
  3. Damper Fork Removal - Rubber Bushing / Bolt ; Seized , Rusted , Frozen , Stuck
    By lilgreenhonda in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-19-2005, 12:45 PM
  4. oil pan stuck
    By mzabeefy in forum 3geez Accords
    Last Post: 12-01-2002, 06:17 PM
  5. 5 Speed oil fill bolt stuck
    Last Post: 09-04-2002, 08:28 AM
