Results 1 to 11 of 11
Thread: Vibrations
    DX User estooie's Avatar
    Dec 2010
    1986 Honda Accord LX-i Hatchback
    Long Beach
    Unhappy Vibrations
    Ok, so I'm still getting used to my car, had it a little over a month, put on 3200 miles.
    I have new tires, balanced, aligned, new brakes all around. I'm still trying to figure what might be causing two vibrations from it.
    One happens around 80mph, and I've had the tire place re-check the balancing, and the other shop for the alignment. It's still there.
    The other happens when I push on the brakes and quickly decelerate. It's not the pedal that's vibrating, more so the whole car doing a little shuddering.
    Ideas please? Btw, I'm not a mechanic, so I might have to bring it in if it requires lifting it and removing parts
    168k & climbing...
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: Vibrations
    The one during decel may be caused by uneven brake wear or the radius rod bushings being bad. If tire alignment and balancing is good, maybe you have a warped wheel, or a jacked up frame :knock on wood:
    '89 SE-i Coupe
    Awaiting Garage
    Re: Vibrations
    ^ I'd count more on brakes. My car shimmied really bad when my brakes were really bad. New brakes, no shimmy.
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: Vibrations
    I'd concentrate on the brakes for the decel shimmy. Your problem is most likely there. I'd attack the bushings first, though. There's always the chance that you'll cure both shimmies by replacing a few worn bushings.
    Those radius rod bushings often aren't checked. If you replace them, purchase Moog bushings, as they're a fairly high durometer polyurethane.
    Re: Vibrations
    check your strut bushings also, mine we're worn really bad causing vibration.
    Re: Vibrations
    If you machine your rotors, the brake shimmy will go away. It will come back in a few thousand miles though, so whatever.
    What kind of tires do you have on the car? If they aren't Michelins, then I'll say that's your 80 mph problem.
    Re: Vibrations
    I have Toyo's and my car doesn't shimmy at 80mph...or 130mph for that matter.
    Dec 2010
    Long Beach
    Re: Vibrations
    Wow, thanks guys. I have Falken Sincera 195/65/15's. I was told that the front brakes were done when I bought it, so I'll have it checked out this week when I get my oil changed.
    As for the bushings, I can have those checked too. How much do those usually run? I read somewhere on here that there's at least 10 bushings that can be replaced?
    168k & climbing...
    Re: Vibrations
    If you were told that the front brakes were done there's a chance just the brake pads were replaced.
    Re: Vibrations
    Agreed, I believe the decelleration shimmy is do to warped brake rotors. And also agree they probably just placed the pads if they fixed the brakes at all. As for the 80mph shimmy, that could be any of the suggestions that have been said, but I'm leaning more towards tire or wheel issues. Maybe you have a warped tire, or bent rim.
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Re: Vibrations
    i had a shudder in mine for a while.
    the passenger side drive shaft intermediate bearing was getting stuffed and caused a vibration that was a pain in the arse to find
  1. Wierd Vibrations......
    By TsubohachiLX-i in forum 3geez Accords
    Last Post: 06-07-2010, 07:53 PM
  2. Mystery Vibrations
    By nfs480 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-17-2010, 05:09 PM
  3. Vibrations when accelerating
    By Toneloc5145 in forum 3geez Accords
    Last Post: 11-05-2006, 08:43 AM
  4. NO good vibrations
    By cyra in forum 3geez Accords
    Last Post: 06-18-2006, 03:54 AM
  5. vibrations need help
    By EricW in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-09-2005, 06:08 PM
