Results 1 to 2 of 2
Thread: axle help!
    Nov 2010
    axle help!
    Ok so Im stuck on a swap as of right now. The swap is a b18a1 engine, i got the harness cut up and rewire base on wiring diagram (thats done), I got the b-series bolt on motor mounts, everything esle has been done its just the axle i am having problems with? before I do anything I want to know the proper way to customize the axle (cutting, welding, or interchange either end of the axle). If possible can you get axles from any company for a bolt in process? let me know what you guys know. thanks
    bridgewater.NS Canada
    Re: axle help!
    Check out the how-to,you'll find everything you need to know about the b-swaps
  1. Axle leak problem (axle will not go in the tranny)
    By Legend_master in forum 3geez Accords
    Last Post: 06-25-2006, 11:03 AM
  2. ..why can't I use this axle?
    By Accordtheory in forum General Engine Swaps
    Last Post: 12-23-2005, 05:55 PM
  3. axle came out¿
    By mag_pbg in forum 3geez Accords
    Last Post: 01-13-2005, 12:04 PM
  4. how can I cut the axle nut off??
    By POS carb in forum 3geez Accords
    Last Post: 11-26-2004, 07:03 AM
  5. Axle Help
    By cubert in forum 3geez Accords
    Last Post: 08-21-2003, 06:55 AM
