Results 1 to 10 of 10
Thread: 86 EFI vs. 88 Carb Exhaust Mani Differences?
    Jul 2009
    Somerville, Alabama
    Question 86 EFI vs. 88 Carb Exhaust Mani Differences?
    I Was Just Sitting Here Thinking, So Awhile Back, When I Rebuilt My 86' A20A3, I Noticed A Large Crack In My Exhaust Manifold. The Only Junkyard Mani I Could Source Was From An 88' A20A1. I Know The 86-87 Are Alittle Different From The 88-89 Which Is What Got Me Wondering This. Seems Kinda Like A Dumb Question, But No Hurt In Asking When The Search Button Fails.
    Other Than The O2 Sensor Bungs Located Opposite Another, And The Different EGR etc. Hole Sizes + Places, But Is There Any Difference In With ID, Size etc. Anything Really Different At All?
    Shaggy
    FF II/ETC I
    Re: 86 EFI vs. 88 Carb Exhaust Mani Differences?
    I might be wrong, but think the EGR are the same on all of them. The thing is the A20A3 efi manifolds have dual downpipe runners, a lot better breathing design, where as the A20A1 is single. Only one 02 sensor on A1, as well. The years I think do not matter as much as the engine being efi or carbed. You can use a efi manifold on a carbed car but not sure if you would want to do visa versa... from performance aspect anyways.
    Jul 2009
    Somerville, Alabama
    So, Best Bet Would Be To Just Go Christmas Shopping And Buy A Pacesetter?
    I Wonder If You Can Get Pink Ceramic Paint? rofl.
    Shaggy
    FF II/ETC I
    im mostly positive that duplicolor makes a pink high temp paint that should work just fine
    1986-1987 fuel-injected cars have single runners, 1988-1989 fuel-injected have dual (update/revision, gives 10 more horsepower).
    All carbureted engines are single.
    carotman's Avatar
    Montreal South Shore
    Technically, the only difference between an 86-87 EFI manifold and an 86-89 carb manifold is the Air Suction pipe fitting (in the US at least)
    I need these parts!
    Jul 2009
    Somerville, Alabama
    So I'm Practically Using The Same Mani, With An Exception To The Carbs Air Suction Hole...Which I Happily Filled With 7014 Stick Weld...lol.
    So The Huge Difference Between The 2 Versions Of The A20 Is Pretty Much Just The Header Adding The Power For The Most Part?
    Shaggy
    FF II/ETC I
    I thought it changed from 4-1 to 4-2-1?
    Jul 2009
    Somerville, Alabama
    Don't Know If This Helps, But It's Off An 86 A20 EFI.
    Shaggy
    FF II/ETC I
    Nov 2010
    Yes the 88-89 exhaust manifolds are a slight improvement over the Carb/older efi version due to 4-2-1 design vs 4-1 design. I would be curious if anyone has dynoed the difference between the 88-89 efi manifold and a header?
    Mike
  1. 2g lude exhaust mani on 3g?
    By JohnBoy in forum Performance
    Last Post: 11-18-2011, 10:46 AM
  2. Replies: 2
    Last Post: 05-21-2011, 01:19 PM
  3. exhaust differences? pics
    By stocklxi in forum EFI Tech
    Last Post: 11-08-2008, 11:20 AM
  4. Exhaust Mani to exhaust pipe bolts frozen! HELP!
    By mocean in forum 3geez Accords
    Last Post: 10-27-2006, 07:35 PM
  5. carb'd guys/girls check this out dual intake mani for...
    By spanky in forum Classic Honda Community Chat
    Last Post: 06-05-2006, 06:49 PM
VigLink badge
