I am needing to find a more reliable car since I had a child back in October. I will admit that this car has some issues still, but considering the members here, most problems should not be that hard to fix, hopefully...
What has been replaced:
Bosch Platinum 4 plugs
NGK Spark Plug Wires
K&N Air FIlter
Radiator
Coolant Temperature Sensor
Main Relay
Valve Cover Gasket
Water Pump
Oil Filter
Fuel Filter
Brake Pads
Brake Shoes
Rotors
Brake Master Cylinders
Igniter Switch
Distributor Cap & Button
Exhaust from the catalytic converter back (glass pack exhaust)
Driver's Side Axle
New Fuel Injector seals
Replaced both rear brake light assemblies
Retapped #1 spark plug with an insert (not a helicoil)
All fluids checked and filled
What needs to be fixed:
Rear Motor Mount
Speedometer 10 MPH off (shows 10 MPH slower than actual speed)
Drivers side front sunroof gutter (leaks during rain if nose down on a hill)
Transmission slipping out of gear randomly (even after adding Lucas)
Gas gauge off by a bit, (shows 1/8th of a tank low)
Oil Pan Gasket
rust stains on interior rear carpet
ECU flashes a code 12 (EGR valve)
Gas smell inside car if left idling in the same spot, can't find the leak
A/C removed (partially before I got it, I removed the compressor and hoses)
Exterior:
Rust on trunk catch area
Rust on front of passenger side rear wheel well
Blue paint/ Tan hood
new-ish 13" used tires
Interior:
Front speakers blown when I got it
No Rear Speakers
Original Factory Tape deck
Interior light not working (just need to reattach blue/white wire to harness near fuse panel)
driver's side window slow to roll up
193,000 miles.
If nothing else, it would make a great parts car if you can't get if fixed. I'd love to get $700 out of it, but am negotiable on the price to a certain extent. Please be able to come pick up the car if you'd like it. Also including (2) Honda Timing Belts, and a new Fuel Filter.
Need to sell as quickly as possible! Hoping to get an '03 Accord next week.
If you have any questions, let me know via PM. I'll try to get some pics posted up tomorrow, depending on the weather.
