Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
Thread: 85 SE-i
    LX User 85SE-i's Avatar
    Jul 2007
    85 Accord SE-i / 89 Accord SE-i
    Grass Valley, CA
    Re: 85 SE-i
    Quote Originally Posted by Ichiban View Post
    Isn't there a bleed screw on the thermostat housing for this very purpose?
    Indeed there is.
    Quote Originally Posted by Christofur View Post
    ill try that i have noticed to when i rev it a little when it goes back down it goes a little past idle then it goes back up. could that be the valve your talking about
    Well, possibly but not likely. With a failing, out of adjustment or sticking fast idle valve, the engine will either idle too high, do the "idle bounce" or it will run poor when cold. Your idle speed is controlled by your IACV (idle air control valve). If it is idling too low or bogs down then picks back up, you either have a faulty IACV or your static idle speed is set incorrectly.
    Here is how you adjust it:
    Fuel Injected Engines
    1985 ACCORD
    Start the engine and allow it to reach normal operating temperature. The cooling fan must come on at least once.
    Connect a suitable tachometer using the manufacturer's instructions.
    Check idle speed with all accessories OFF.
    NOTE: To prevent the idle control system from operating, pinch off vacuum hose number "27.''
    Idle speed should be 700–800 rpm (in neutral). Adjust the idle speed, if necessary, by turning idle adjusting screw.
    Fig. 4: Idle adjustment screw on 1985 Accord
    Check the idle controller boosted speed with the air conditioning ON. Idle speed should be 750–850 rpm (in neutral).
    Adjust idle speed, if necessary, by turning the air conditioning idle adjusting screw.
    And Thats The Bottom Line... Because Stone Cold Said So!
    Current Vehicles: 03 Ford F250 Super Duty 4x4 Diesel, 83 Chevrolet K5 Blazer 4x4, 94 Civic 2dr EX 4AT, 99 Civic 3dr DX 5MT
    Re: 85 SE-i
    It's so cool that we have an SEi expert here!
