Results 1 to 13 of 13
Thread: how easy is it to......
    DX User RandyAM's Avatar
    Nov 2010
    1988 Honda Accord EXi
    British Columbia
    replace my transmission??
    it clunks BADLY in 2nd gear when its warm, and clunks sometimes in 3rd gear.
    is it easier to rebuild, or should i just replace??
    A20A3 5spd Manual Trans
    208,000kms + Original everything
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    Re: how easy is it to......
    have u tryed to replace all of ur trans fluid?
    that might help it for right now
    Mar 2010
    88 lxi
    lawrenceville, GA
    if i were you i would replace it so you can drive it for a while then slowly rebuild yours. theyre not that expensive to find.
    88 lxi:
    Nov 2010
    British Columbia
    yeah, i changed the MTF, and its still bad.
    i can get a rebuilt one with 20K on it for $375
    May 2010
    1986 accord LXI
    Chicago Il
    Quote Originally Posted by RandyAM View Post
    thats not bad i just put a trans in my 01 f-150 it was 1400
    If you're getting it from a junkyard or Craigslist, not worth it.
    Replacing the trans should be pretty straightforward. Just follow the manual (available here starting on p. 14-3) and take your time. I got a very good rebuilt trans from www.mantrans.com. I would recommend them over any other option. Definitely change the clutch while you have it out.
    I'm having trouble understanding your symptoms. A more likely cause for a clunk on an MT would be a clutch out of adjustment or needing replacement.
    or worn motor mounts or a worn dogbone mount. lower gears will cause a louder clunk since you are creating more torque
    Nov 2010
    British Columbia
    i'll see if i can take a video with my phone, and you can see what i mean
    snoopyloopy's Avatar
    Killa Cali
    it's not overly difficult, especially if you have a companion. budget 3-4 hrs for your first time.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Talking Re: how easy is it to......
    It's really about 5-6 hours for first timers (depending on knowledge & tools) & around 2-3 hours for the experienced.
    ya i can drop one in about 30-40 mins now putting it back up is the hard part def one 1 or 2 extra sets of hands to do that
    Jan 2009
    89 Accord LX-i coupe
    Illinois
    A "clunk" really sounds more like motor mounts (dogbone or front/rear) or a clutch. Check the cheap/easy stuff first. We don't want to see you doing a trans swap and ending up with the same symptoms.
    1989 Honda Accord LX-i daily driver.
    1989 Honda Accord LX-i project car.
  1. how easy?
    By Vick23 in forum Newbie Introductions
    Last Post: 10-13-2011, 09:56 PM
  2. Okay, here's an easy one
    By Sabz5150 in forum 3geez Accords
    Last Post: 02-02-2010, 07:19 AM
  3. Is it this easy?
    By REn0 in forum Performance
    Last Post: 01-17-2007, 12:00 PM
  4. Is It Really This Easy?
    By ezeedee in forum General Engine Swaps
    Last Post: 12-02-2006, 04:53 AM
  5. Easy Fix!
    By BlueBead in forum 3geez Accords
    Last Post: 01-19-2005, 05:44 PM
