Results 1 to 11 of 11
Thread: Rev and Acceleration
    DX User rideordie12's Avatar
    Sep 2010
    93 EG sedan*sold* 93 prelude*sold* 90 EF sedan*sold* DA integra *totaled R.I.P.* -93 EG sedan -83 SZ accord sedan
    Puget sound, WA
    Ok i donno if this has been happening since i did the swap or when i got the car with this motor.
    When i idle at cold or operating temp and rev it up
    1. it takes two or three seconds to idle down..
    2. It feels like it should gain rpm faster like its slow or something
    THEN...
    When im driving and take off it it feels as though its almost putting while accelerating and doesn't take off like it feels it should while stepping on it in any gear???
    Any ideas?
    -MALACHi
    Re: Rev and Acceleration
    Have you checked your timing? Could be too advanced, causing the excess idle.. I dunno, just a quick guess, easy to check...
    LX User Jajle's Avatar
    May 2010
    1989 Honda Accord SE-i Coupe
    Yukon, Oklahoma
    Does this just happen for a while after you start your car? Then after you drive it for a bit it'll drive correct?
    I love my 3Gee so much!
    Ichiban's Avatar
    North of You.
    Leaking spark plug wire and slight ignition miss? Fire it up in the dark and look for blue sparks. Actually, sounds more vaguely like a vacuum leak..
    ICHIBAN!
    "Now, even more better!"
    What did you swap?
    What condition is your carb in?
    How old is your cat?
    ...by which I mean your catalytic converter. (I know some wag is going to make a joke about felines.)
    Sep 2010
    Puget sound, WA
    Tried adjusting the timing... no difference
    Quote Originally Posted by Jajle View Post
    I thought that it did go away at first after i drove a bit but im not sure thinking back on it..
    Quote Originally Posted by Ichiban View Post
    I didnt see any blue spark and i did the timing last night after i got off work so it was dark also. I though vac leak also so i looked over everything and looks all to be connected (didnt check in vac box though).
    What did you swap?
    Im new to carbs so im not sure.... I know its not the answer your looking for but it is kinda grimey, but clean to the eye on the inside.
    The cat is prob pretty old, and i did punch it also so it is more like a test pipe..... Ive done it to almost all my cars so i figured it wouldnt hurt,, could that be the problem???? Not enought back pressure or something??
    -MALACHi
    I was thinking that if the cat were plugged you would lose a lot of power to it. Exhaust restrictions will make the car feel like it has no power without giving any other real symptoms. If you punched it out, it wouldn't be that. I feel that carbs are something you should rebuild every 100k miles or so. If it's been longer than that, it's probably time. You can wait for it to give you problems, but it's easier to do it while it's running good.
    Sep 2010
    Puget sound, WA
    Well that makes sence. I didnt think that not enough back pressure would be the problem, since most cars have enough from the exhaust manifold alone, and will only backfire from too much unused fuel.
    On the other hand since the emmisions stuff on this motor compared to the stock (stock: low emmisions swapped motor: high emmisions) is different that i would switch out the carb on the stock motor (which is new) and the one on (this which is not) to see if this would make a difference.Slakin gettin the weber carb and eleminating all these problems since i found a 4dr EG like my other car that im tryin to pickin up thurs
    -MALACHi
    Sep 2010
    Puget sound, WA
    Well i didnt go as far as rebuilding it but i did clean the crap outta it and the problem is fixed (for now anyways hahah)!!! sweeeeeeeettt.
    -MALACHi
    Ichiban's Avatar
    North of You.
    I'd transfer all the new/non emissions parts from the old motor to the new one.
    ICHIBAN!
    Sep 2010
    Puget sound, WA
    Well i ended up gettin stuck in tacoma and driving back with it acting like it wasnt getting gas, so i ended up swapping out the carbs and it runs great now that i dont have all that "high altitude" emmissions stuff. Seems like better gas milage, quicker response and quicker exceleration also.. I'm guessing that it was just way overdue on a rebuild. This one was rebuilt while trying to decifer the no fuel problem by the OG owner.
    -MALACHi
  1. Hissing at Acceleration between 1-3K RPM
    By Discovery in forum Carburetor Tech
    Last Post: 11-02-2011, 08:55 AM
  2. Car vibrates under acceleration
    By kinabalu in forum 3geez Accords
    Last Post: 06-09-2006, 09:03 AM
  3. acceleration
    By jacc420 in forum 3geez Accords
    Last Post: 12-11-2003, 08:41 AM
  4. acceleration help
    By GDGuy11B in forum Performance
    Last Post: 11-10-2002, 01:26 AM
  5. Acceleration.....
    By 89AccordExi in forum Performance
    Last Post: 07-16-2002, 12:57 PM
