Results 1 to 25 of 34
Thread: wrecked diff?
    Unhappy wrecked diff?
    i have this problem where my car randomly makes a clunk when i take off, not as soon as I apply load on the wheels, but about 1 second after I've started moving. I thought it was my engine mounts, but after replacing them (solid ones with stock ones) the problem became worse (I might just swap the other ones back in)
    well today I found out there's lots of play in the diff (i think?) I put the car in gear, jack up one side, and i can rotate the wheel about 45 degrees before it stops. same goes with both sides, I checked the axles & intermediate shaft, all of which are in good condition, meaning the play is inside the gearbox somewhere.... so what do now? I need this car to work properly over the next few weeks reliably, cause I'd rather not be stranded in the middle of nowhere
    Re: wrecked diff?
    it only makes the clunk sound when moderately turning at low speed. when driving at a decent speed (30-40kph +) it's goes fine. also when rolling to a stop it sounds like you can hear something in the engine bay broken rattling around? but once stopped, you can't hear it anymore.
    i need help fast, i will convert the car back to auto if i need to as a very last resort. i've got 4 days before long trips begin
    Re: wrecked diff?
    bump
    Re: wrecked diff?
    are you sure it's not something loose like flywheel bolts or something broke in the clutch? Mine has been like that for years and I've never had an issue
    Re: wrecked diff?
    hmm good thinking, i hope its something like that. I'll try and check that now. hopefully that can be done by just removing that little cover
    Re: wrecked diff?
    okay diff is indeed fucked. i pulled one cv joint out, and after all the metal oil came out, I could stick my finger in there & wriggle that pin all over the place. bugga. now I have to find all my automatic conversion stuff
    Re: wrecked diff?
    That sucks man. You're more mechanic than I am that you are just going to convert your car back to AT in 4 days. You make it sound like changing your socks. Good luck with that.
    I have to ask though: how in God's name did you break a diff?
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    Re: wrecked diff?
    I went through 2 tranny's. blew up both diffs. They are weak. Open diffs FTL.
    Feb 2004
    89 accord lxi
    down by the bay
    Re: wrecked diff?
    Yup, I've had a diff explode too. But it was a used transmission that I hadn't bothered to rebuild.
    Left behind a trail of oil, pinion gears and aluminum shrapnel on the road. Like a giant snail robot.
    Re: wrecked diff?
    what the flying blueberry FUCK!!
    I got the auto box bolted on to the motor all sweet as, nothing out of the ordinary, then as im lifting the lot on the hoist, this happened:
    now I only have 2 more working b20a gearboxes
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Re: wrecked diff?
    what a rough prick!
    Re: wrecked diff?
    hay it was all going just like your normal swap, no idea why that happened though. now for some more bad luck, the other b20a box wont even bolt on to the motor???
    I have a b20a bolted to a auto box behind the garage, ill drag that out tomorrow since it's all together & working & put that in the car. fun
    Re: wrecked diff?
    okay auto conversion is done minus atf, I will be so pissed if the car wont move with that stuff in it
    Re: wrecked diff?
    woot car drives now yay
    Re: wrecked diff?
    whats the engine like???lol
    Re: wrecked diff?
    the engine seems a lot better than the other one! it doesn't smoke at all unlike what the other one did, feels like it has moar power too
    Re: wrecked diff?
    win win..................wait... an auto feels more powerful than a manual?!?!?! was ur other engine a blacktop and this a gold top?!?!
    Feb 2004
    1988 LX Sedan
    East TN
    Re: wrecked diff?
    What happened to the auto trans to cause the crack? Did it fall when lifting it into the car?
    Re: wrecked diff?
    yes what made that case crack like that, inquiring minds need nourishment..
    Im glad you got wheels rolling again!
    Re: wrecked diff?
    is the pin supposed to look like this?
    Re: wrecked diff?
    man i laughed so hard when u sent me that pic, even the sattelite tv guy that was here at the time was like wtf lol. spider gears ate the pin away.
    Re: wrecked diff?
    okay so i smashed apart a auto gaybox
    and got teh diff out
    only to find out it's different to the manual diff
    fail.
    i took the inside gear thingies out of teh auto diff and stuck them in the manual one
    seems to fit, i haven't put the pin in yet though, but here's a comparison between a good, worn & broken pin lol
    lets hope this all goes back together well. First time I've pulled a gearbox apart
    Sep 2007
    new zealand
    Re: wrecked diff?
    hope it duz work eh.
    then just dont beat on it so much
    Re: wrecked diff?
    hope it works
    Re: wrecked diff?
    well i stuck the pin in, fitted with a little bit of hammer, everything feels good so now lets put it back together
  1. 2gen and 3gen struts diff?
    By shepherd79 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-29-2007, 03:27 PM
  2. Whats the diff?
    By 86hatch in forum 3geez Accords
    Last Post: 04-02-2007, 06:50 PM
  3. is there a diff between ..
    By bboipinoy112 in forum Classic Honda Community Chat
    Last Post: 08-11-2003, 05:37 AM
  4. PS sensor diff.
    By shepherd79 in forum 3geez Accords
    Last Post: 04-19-2003, 07:35 AM
  5. LX and LXI cam diff.
    By shepherd79 in forum Performance
    Last Post: 06-10-2002, 02:07 PM
