Results 1 to 12 of 12
Thread: tranny help
    Nov 2010
    tranny help
    Im doing a auto to 5spd swap. I have read in the other post what I needed but it doesn't include the starter and I was just wandering if I needed the 5spd starter or the automatic transmission starter would work fine? Let know guys. Thanks
    Re: tranny help
    The people who post those kinds of threads are usually very complete, so I'm guessing since they didn't post that a different starter was needed you're fine with the original. I think the two different starters for these cars is carbureted versus fuel-injected.
    Nov 2010
    Re: tranny help
    probably, thanks alot though. If anyone reading this can answer one more question is- How do i go about removing the crank pulley, I notice the usual honda crank pulley tool cant be use. How would you go about removing the crank pulley? Any information would help alot.
    bridgewater.NS Canada
    Re: tranny help
    There is a difference,the manual starter is adjustable .The auto one is not,but it may work.I think the nose piece can be inter-changeable.
    Re: tranny help
    the only difference in starters is the nose piece. change that out and you will be fine.
    Re: tranny help
    Quote Originally Posted by shepherd79 View Post
    I was thinking the bolt holes were different, i looked at the manual and it shows three different starters, one is for the European models, and two for the US models, I think the auto and manual are different. all three are different models
    Nov 2010
    Re: tranny help
    I have a question regarding this hose thing on the transmission. Where does this hose go?
    Nov 2010
    Re: tranny help
    i have a arrow pointing to it?
    Re: tranny help
    Quote Originally Posted by prince_frog View Post
    picture? on the manual? it's probably the vent hose
    Nov 2010
    Re: tranny help
    the hose is above the the clutch fork, clutch cable connection. Does this hose connect to anything?
    Re: tranny help
    thats just a vent, it doesn't go to anything,it needs to stay over like that to prevent water from getting in
    Nov 2010
    Re: tranny help
    oh ok thanks
  1. tranny shift problem possably bad tranny
    By xxxfrankensteinxxx in forum 3geez Accords
    Last Post: 05-05-2008, 08:50 PM
  2. Tranny
    Last Post: 01-15-2006, 11:58 PM
  3. does all honda tranny use motor oil in the manual tranny?
    By 1988_5spd_lxi in forum 3geez Accords
    Last Post: 01-08-2004, 10:29 PM
  4. Replies: 3
    Last Post: 06-17-2003, 04:54 PM
  5. tranny went out
    By franks89sir in forum 3geez Accords
    Last Post: 01-04-2003, 11:39 PM
