It's part of the PCV System I believe it separates the Oil And the Air? So the oil drains back into the pan and the air goes into the intake to be burned?
do you need the part with the PCV valve sticking out of it? is that the part thats broke? I've got one in pretty decent shape if you need it
88 lxi:
is there any other way to bypass this? the guy at autozone says you can but he couldnt explain how w/o seeing the car and he cant go on school grounds so.... you guys would be a great help. Also, the plate that covers the flexpalate is confusing me. idk how to put it bac on.. do i just slip it o while im installing the trans? or is there some way to install?
88 lxi:
still havent figured this out. this and reinstailling the harness is the only thing in my way... so far
88 lxi:
I got it rigged finally. I used a grommets from autozone and bought a pcv that would fit and just ran a 3/8 hose into the manifold. So next on my list is to reinstall the manifold and begin pricing everything back together. I'm still waiting for to get my computer back so I can order my lowering springs. And also today I picked up a new downpipe from a clean ass accord they just got at pull a part. So harness is next. Can't wait to try and crank it
88 lxi:
Oh yeah if you need any AC components I have the whole ac system from one of my cars for sell.
~~NGK~~Silvania~~MSD~~Pioneer~~MSW~~Bosch~~DC Sports~~115WHP 116WTQ
Lmao I haven't bumped it for a while but i have ac stuff on the board for sale too
88 lxi:
ok heres a quick update on the car... i have the trans intaslled w/ the cpver plate... except for one bolt on the transmission... its the bolt that holds a bracket with a hose coming off of it. its towards the front of the trans. if i was comparing to a clock id say its at about 4 oclock'ish. but another thing about my PCV system... i rigged it to work (hopefully) basically what i did was i bought a grommet for the oil seperator box, bought a pcv valve to stick out from it and ran a hose from that pcv valve to the manifold... i think itll work but if anyone has any objections please come foward
88 lxi:
I broke the PCV system while I was rebuilding my engine. I replaced it all with new and junkyard parts. Pretty much everything from the oil pan hose to the PCV valve is all replaced. I think others are running homemade catch cans, though.
Good luck with the rest of your build.
but it think my setup would work right? theoretically i think its the same minus one pcv valve. right???
88 lxi:
You'll know when your air filter clogs full of oil.
I don't know for sure, but I suspect you'll see a lot of oil in your air filter.
hmmm... im trying to figure out why you suspect that... i can add another pcv valve to be sure so ill do that. but other than that does the system include anything more than that? from my inspection it just goes box, grommet, pcv vlave, tube w/ turn in it, pcv valve, hose to manifold. correct me if im mistakin
88 lxi:
so any input???
88 lxi:
Okay, I might have read your original post too quickly. There should only be one PCV valve. There's the hose from the pan to the breather box. The grommet is on top and curves up to the valve. Then the hose from the valve back to the intake. That should do it. Where are you getting two valves from?
it was an extra i had from the original but i thought you were telling me to add another one to the system... but heres my layout of what im going to be using. hose from the pan to the box, grommet and pcv valve coming from the box, hose coming from pcv valve stright to intake manifold.... im almost sure its a ghetto replica of the system. im almost sure it will work dont you???
88 lxi:
Sounds fine. Sorry for not paying better attention.
Lol you scared me for a second...
88 lxi:
ok well the motors back in the car nowbut me and my friends noticed it sits at an angle. its like the trans side it sticking up a little so it leans to the rght. i think i remember someone saying its the miscreated mounts that are sold but im not sure. so any input guys?
88 lxi:
you got the b20 lean
lol yea on an a20... but it wont effect it will it? as far as perofrming correctly goes?
88 lxi:
Ok I've made alot of progress in the past few days I've almost completed wiring and vacuum layout but I can't figure out where these two plugs go. There is a green and yellow plug that are just hanging out around the radiator and the transmission. They aren't the ones that plug into the coolant port . Also if anyone knows where I can get a diagram of the coolant hose layout or wants to post some pics that would also be helpful
88 lxi:
