not much to update on recently but did find a leak where the thermostat housing meets the head so i ordered a new gasket and got the thermostat gasket instead of the surface gasket but since it was 2 bucks i kept it and ordered the right one as well. im glad i did cuz it was ready to go... so thats in already and the new one should be going in wednesday. then im throwing it all back together, refilling the radiator, driving around with less atf, and bleeding the coolant system. just to be sure to blled the coolant i need to let it warm up real good, and while its running loosen the bleeder screw until the stream soming out is 100% water correct?
