you can probably have the timing set with a few more degrees of advance than the factory says with your current set up, makes a huge difference but dont giver too much to get preignition etc..
Awesome you got the problem figured out, congrats!
I just made my first long trip after the swap. Initial impressions, I'm VERY happy with the swap and am glad that I did it. I was able to maintain speed on the highway and accelerate up hills (that never happened before). It is very smooth running and easier on the gas. The fuel economy was one of my main goals with this swap so here it is...
Brand new spark plugs
Fresh oil change
Tire pressure at 36 psi all the way around
17* of timing advance
~150 lb of stuff plus myself (180 lb)
Straight highway miles
Average speed 75 mph
208 miles
8 gallons
= 26 mpg
**** When I filled up initially it seemed that the gas pump clicked off early, then when I filled up at the end the gas pump overfilled it and some gas actually ran out. This is skewing this test some but 26 mpg is the worst case.
I have my jet sizes written down somewhere so I'll update this with those later.
Overall, I'm very satisfied with this thus far. I still have some tweaking to do and I would be perfectly happy with 30 mpg on the highway.
Just wanted to update this yet again. It has been consistently in the single digits every morning and with one press of the pedal to the floor and a turn of the key it starts up every time. I have to adjust the fast idle, but right now on start up it will idle around 1200-1500 RPM. Holds a nice smooth idle until warm. I'm still very impressed with this setup and no complaints thus far.
Well I'm not so excited by my latest results. I just went through my first tank since the swap in all around town driving. The drives are on average less than 5 miles and the engine cools off completely before every drive. By far not optimal for fuel efficiency. I calculated 13.5 mpg....
However... I'm impatatient and did not give the car time to warm up before driving. Therefore I would be driving with the choke engaged and most likely dumping fuel. This tank I'm going to try and warm the car up before each drive now that I have the fast idle control working. I will see how much this improves my efficiency. Fingers crossed.
