Hey guys,
I have been around this site quite a bit researching and reading everything that I could about weber carbs. My car was still running fine, but definitely way out of tune with less than 10 mpg around town and not even peaking at 20 mpg on the highway. The motor still ran strong the carb was just dumping fuel through it. I took a lot of pictures during the process and I hope that I can help someone else in the future.
I stalked ebay or a while for carbs. I ended up buying two 32/36 DFAV carbs. One for 30.00 that had been sitting for a while that I was mainly using for parts and another for 70.00 that was on a running vehicle but missing the choke assembly. I also bought the adapter plate and carb rebuild kit and got to work. I inspected the running carb from top to bottom and cleaned it thoroughly. Then I took the choke assembly off the carb that had been sitting, revamped it, and installed it on the good carb. In the end, I had one complete carb.
Then I got to work on removing the stock carb. It was basically a tornado of ripping out vacuum lines and it felt o so good. Basically any vacuum line attached directly to the carb was removed. Here is what I kepts:
1. Brake booster vacuum line from manifold to the brake booster (left as stock)
2. PCV (positive crankcase ventilation) system hooked up. It has one vacuum tube that runs up through the intake manifold and I looped it back to a vacuum source on the manifold.
3. The vacuum advance on the distributor. I tied both of the lines together and connected them to the vacuum tree on the back of the manifold.
For the dreaded TV cable and throttle cable I took the stock carb cable plates off. I used both the plate for the throttle cable and the TV cable. I modified them with a dremel to fit on the shaft of the Weber carb. It is the exact same shape (circle with two flattened edges) just larger. Then I threaded a nut halfway onto the Weber carb shaft and loctited it like no other. I modified a bolt to have the two flat portions that fit into the modified stock carb plates and cut off the bolt head. It was basically a stud that replicated the Weber carb shaft. I then threaded this into the bolt that was halfway threaded onto the Weber throttle shaft and also loctited it. I was able to slip on the two stock carb plates and put a nut on to tighten it all down. This turned out to have the perfect amount of rotation and accepted both the TV cable and throttle cable with ease.
Then for the throttle cable and TV cable braket. I hacked off the ends of the stock brackets that hold the cable to reuse. I did some modifying and welding to create new brackets to hold each cable. I will post pictures of these so you can better understand it. The throttle cable holder uses the two front mounting points for the carb. The TV cable holder uses two unused bolt holes on the intake manifold. This setup has smooth actuation and goes all the way to WOT with ease.
I removed the EGR as well as the AS valve. I created a block off plate for the AS valve and removed both tubes coming off of the exhaust header. Royal pain for anyone trying to do this. The nuts going into the exhaust manifold have been through many heat cycles and make it a giant paint to remove. I had to remove the radiator to have enough room to get the bolts off. Once off I welded a plate over the opening of the nuts and threaded them back in with some high temp RTV on the threads.
Today I'm waiting on my last puzzle piece. My fuel pressure regulator will be showing up today so I can install it and attempt to start it. I will be sure to updated this with any findings and how it goes. I will also upload tons of pictures of the whole process. If anyone has any comments about my process or questions feel free to let me know.
Thanks!
