Have this problem for a while now. Light comes on after engine warms up and high rpms. Took off the EGR Valve and cleaned out the carbon with cleaner thoroughly. No Fix. While idleing, I reached down and lifted the valve manually causing the car to want to stall(does this mean the ports are clean?) Also removed the lift sensor to see if the valve was moving after the light had come on. No movement. Would the valve open if the car is idleing? Only thing i can think of is there is not enough of a vacuum to open the valve. Possible clogged vacuum chamber? Could the sensor be bad? Does it have anything to do with the operation of the valve itself or does it just report back to the ECM? What do I do?!?!
