Made one 5 feet long harness, Labeled each wire with the name of the signal it will carry.
Decided to modify my ECU instead of the car's harness, so if I screw up something, I just buy another ECU.
Each cable is soldered to the ECU, An advise if you ever solder something, put some solder to the wire and to the PCB, then join them and apply heat with the iron. It will allow the solder to reflow better, also, this way there is no need of a third arm to hold the solder while you are holding the iron and the wire.
How the PCB looks after the wires were soldered
Putting together the ECU again.
There is plenty of room for the wires below the PCB
