Results 1 to 10 of 10
Thread: car starts a little funny after timing belt broke and was replaced
    Oct 2002
    Pompano Beach, Florida
    sounds like it is "choking" when it starts but then it starts right up, but misses for about 1 minute
    it doesnt affect drivability at all though...does this mean that a valve is bent?
    1988 Honda Accord DX Hatchback 5 spd (blown 5th gear) red, new windshield, new master cylinder, minor front end damage popups always up, nice paint on body otherwise, nice interior, axles creaking due to visibly torn cv boots, flipped lid, new turn signal module, rebuilt "performance" motor with 12k miles on it...am/fm cass pullout
    166k miles
    LXi User BoredRec's Avatar
    Nov 2001
    1988 Honda Accord LXi
    Las Vegas
    Most likely, do a cylinder leak down to determine if there is a bent valve.
    1988 Accord LXi Sedan
    Custom Cold Air Intake -- Custom Exhaust -- Neuspeed Springs -- ACT Stage II Clutch
    Alpine 9815 -- MTX 2300X -- 2 JL 10W3V2's
    Oct 2002
    would a standard compression test help me out? or no
    166k miles
    Nov 2001
    Las Vegas
    Yeah, actually I think that might work...if a valve is bent it should have a lower compression compared to other cylinders...make sure you do all 4 so you have something to compare it too.
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    If I understand your statement correctly, no it won't help you out
    It's just a test to see if your compressions on all cylinders are okie, eliminating the idea of a bent valve.
    Nov 2001
    Las Vegas
    Not entirely true...to have compression you must have a sealed combustion chamber. If a valve is bent you won't have a complete seal, therefore have lower compression readings. Air will be escaping past the bent valve. You should also notice the car sounds a little funny during start up. It mind sound sorta like "cha-cha-cha-whee-cha-cha-cha-whee" being that "whee" less compression than the others, causing the engine to spin faster as that cylinder comes up to TDC.
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    it misses? hmmm when you change timing belts do you need to readjust timing?
    Oct 2002
    were you reffering to ingnition timing?
    i heard that this could be the problem
    Jun 2002
    '89 accord lx-i
    lol, my timing belt use to make screaming sounds, i cant get anywhere with it, cant sneak out the car at nite, becuase the sound is so loud and ppl wakes up from it, this was on my 84 accord tho...hehe back in the days =)
    '89 accord lx-i coupe
    2005 Mazda 3
    Ontario Canada eh.
    yup
  1. What happens when your Timing Belt goes?
    By Oz87Si in forum 3geez Accords
    Last Post: 03-13-2008, 04:31 AM
  2. Timing belt broke..... help wanted
    By 87preludeA20A3 in forum 3geez Accords
    Last Post: 02-04-2006, 05:25 PM
  3. timing belt broke HELP!!
    By thundertank in forum Performance
    Last Post: 07-30-2003, 01:22 PM
  4. WHich timing belt??
    By Dutchboy in forum 3geez Accords
    Last Post: 09-22-2002, 12:07 PM
  5. Car starts funny...
    By Coitis1 in forum 3geez Accords
    Last Post: 08-01-2002, 08:38 PM
