instead of 82.50 they are 82.75
I was suggested to make them 83.00 , is it ok ? can I find a suitable piston kit with rings for this size?
if not , what do you recoomend?
thanks,
Adrian.
thanks,
Adrian.
You need to ask this question of a competent machine shop. Have them bore out the cylinders, prep the block, test it and get a ring kit to fit the bore. It's all in a day's work for a good machine shop.
You'll need to change the pistons too.
I know Honda sells an oversize kit.
I need these parts!
my car is the only 86(-89) Accord in Israel , it wasn't imported reguraliry here.
the machine shop can't find pistons and rings for my car.
I want to order this kit, but will it match? they say they have rings up to +40 , it means 82.90 ?
if you cant find a 83mm piston its not wise to bore it out that big
I'm waiting with the machining till I find the parts..
I also fount these 82.75 pistons
http://cgi.ebay.com/ebaymotors/ws/eB...m=370340800991
83mm b18a/b pistons with b18a/b rods.
"Integra ls"
un-motivated!
3GR
I should look after a set o those and will be straight fit ?
yup, after a overbore.
un-motivated!
3GR
b series show 81mm![]()
yup. these will be in the aftermarket. Sorry, I should have been clear.
un-motivated!
3GR
Your not understanding the measurements.
They typically sell oversize pistons & rings in thousandths of an inch., +20 =
.020" +30= .030" & +40 = .040"
Your best bet is to have a machine shop measure them, cause that is way out of limits. If your measurement is accurate, you'll have to bore it out to 83 mm..
NVM. my pistons are about 83mm.
and where did you find pistons and rings?
You are not understanding metric measurements.
.040" is roughly 1 mm. So .010" is about 1/4 mm, .020" is about 1/2 mm, and so on.
If the stock bore is 82.5mm, and his is 82.75mm, then simple math would explain he has about a .010" overbore.
If his bore is still acceptably within limits of a +.25mm overbore, then he shouldn't have to bore it at all, simply match the proper pistons to it.
If the pistons are also acceptable size, they can be reused.
my pistons look usable in your opinion?
https://www.3geez.com/forum/showpost....8&postcount=47
and if the diameter is acceptable , the scratches aren't bad to the new bored cylinders?
I was trying to explain the ebay link he had with pistons & how they sell them in sizes. I wasn't sure either if he was using metric or what in his measurements. .25 mm over isn't bad. Might be able to hone it out if the walls aren't tapered & it's perfectly round at several points.
I'm not much on re-using pistons when your that deep into it, but I guess it depends on the buget.
I'm really confused
this auction says "THIS AUCTION IS FOR STANDARD BORE PLUS .030""
but in the details they say :
ACCORD DX
LX
1955CC
4 CYL
8.8:1
82.75MM
BS1
12V
1986
OVER HEAD CAMSHAFT (OHC)
if it is standart bore , why is it 82.75?
will this kit be good for me?
My Haynes manual says the standard pistons are 82.67 mm.... My Chilton book didn't give specs.
82.67 + (.030") or .762 mm = 83.43 mm
82.67 + (.020") or .51 mm = 83.18 mm
82.67 + (.010") or .254 mm = 82.92 mm
It looks like he is using 82.75 as standard bore size. It also looks like that the smallest pistons/rings he has are .020" over. which is 83.18mm. (His pistons will actually be 83.26 mm at .020" or .51 mm over.)
I would e-mail him and ask what the total diameter is on his .020" pistons & rings. See if its close to 83.18 mm.. Looks like you might be boring that baby out to 83.26 mm. with his math.
You'll have to take it to a machine shop to have the wrist pins inserted. (I don't recommend doing it yourself)
