Page 1 of 5 12345 LastLast
Results 1 to 25 of 119
Thread: new s&s header
    new s&s header
    ok it finally got here, a family member paid for it for my christmas present, it's sad to see a company thats been around so long go under, these are excellent headers, and look to be very well made, S&s had a very solid reputation going all the way back to '68 i believe. I got rid of the air fittings today, no point in them sticking out of the side of the header not connected to anything, I split a piece of stainless steel exaust tubing and it fit perfectly on the header tube,after cuttiing off and grinding down the two fittings, David maule migged it up for me, when this entire system is fitted and on the car, eventually i'll send these off to be Jet hot coated, they last pretty much forever that way. the paint on them never lasts. I have to make a bracket to mount to the rear exaust hanger on the engine. I'm thinking of making something to protect the tubes from road damage.
    LX User 1813mdw's Avatar
    Nov 2010
    Jackson, Michigan
    Re: new s&s header
    damn, those are nice.
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Re: new s&s header
    I WANT IT!! How much do you want for it. pretty clean lost
    Re: new s&s header
    Looking good dude.
    Re: new s&s header
    thanks, it will be nicer when it's all on the car and it's running, I was given a specific amount of money for christmas by a family member that was designated to be spend on the car, i'm supposed to send pictures of what i got with it , i would have spent it on bills but was told it was for my car only
    AZ
    Re: new s&s header
    obx makes the same design header now for 200. buy that.
    dead white and blue
    LX User rustlude87's Avatar
    1987 Honda Prelude Si
    Re: new s&s header
    I love the S&S header the only thing is that it hangs really low, Lost I'm sure you'll be happy with the gains. I actually gained low end torque lol
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Re: new s&s header
    Might want to get rid of that shitty ball joint before you get it coated.
    Andrew.
    Re: new s&s header
    Quote Originally Posted by rustlude87 View Post
    I'm going to make something to protect it from road scrapes and flying rocks etc,
    yea it's going, it's going to be quite a while before I can afford to coat it, right now I just want to get it mounted and the brackets made etc.
    Re: new s&s header
    the obx was 179 on egay, I have no idea how the quality is though, isn't it Chinese made? I know the s&s ones have a reputation for excellent quality. It sucks they went out of business, they've been making great headers for a long time, all of their equipment was sold off at auction last year
    Oct 2009
    Re: new s&s header
    true it looks the same i might look into it. thanks stat1k
    Re: new s&s header
    one of the pipes that came with this used to go to the converter, it's got the nice heavy flange with three bolt holes, I think I have the converter side of that flange, if I can find it, it takes the factory graphite O ring gasket, I'll put that flange on the end of the header, that way it won't have the loose flange thing from the socket rattling around on it, I could see that being an issue when being coated. If I can't find it, I'll make another identical flange and make a flat gasket like the ones used on header flange connectors. the other end will get welded to the flex coupling, when I make those, I weld three bolts right into one side of the flange, like studs
    Re: new s&s header
    I KNEW I saved that converter flange for a reason, never throw out anything made of metal, FOUND IT!! and it matches the other side of the flange in the header kit, now i can use the solid flange instead of that socket joint, it uses a factory seal,
    flange from kit
    factory flange, with LOVELY muffler shop welds, even lots of wire from the mig welder, this is why i hate other shops doing work,i need to cut off and clean up this mess
    working on some bends
    1988 Accord LX-i
    Delaware County
    Re: new s&s header
    Glad your enjoying the header, it looks good. Ill let you know if I come across another one haha. And even though its a shame the company went out of business everyone who has one should be happy, they were originally like $325 or something like that.
    Re: new s&s header
    Re: new s&s header
    Dude, you're good.
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    Re: new s&s header
    i assume you are still going to use a flex pipe rather than the ball joint being the end is switched
    3Geez resident body man
    Owner of Wreck-less auto body
    Re: new s&s header
    of course, the flex pipe goes to the other end of the flange
    Re: new s&s header
    pictures up in a few minutes, they had to go in long enough to mark the brackets tomorrow, why they couldn't weld on a simple two hole tab at the factory,i'll never know, none of the headers for this engine have that, but it's needed to hang them under the engine, i jacked the engine up at a crazy angle off of the front motor mount, then it slid up from underneath once i rotated the dipstick out of the way
    Re: new s&s header
    they are in for the moment to check clearances, and to figure out where the hanger bracket needs to go.
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    Re: new s&s header
    My pace setter had the mounting tab with two hole in it for the rear of the engine.
    Re: new s&s header
    Quote Originally Posted by Bglad420 View Post
    yea i'll just make a piece of angle iron with the slots like factory, once it's bolted to the hanger i can clamp it to the headers and mark them where it goes, then it gets welded on like factory, did it have a mouting tab at the font of the engine?
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    Re: new s&s header
    No, And it doesnt really need it beings that it's not 100lbs of cast iron.
    Re: new s&s header
    yea i have two cast factory manifolds now, maby i'll put a bar between them and use them as a free weight
    Re: new s&s header
    NICE! looking good tim!
  1. Wtb header
    By da9 in forum Wanted
    Last Post: 01-20-2010, 12:39 PM
  2. DC header
    By Nio in forum Performance
    Last Post: 01-03-2010, 06:11 PM
  3. DC Header
    By 'A20A3' in forum Performance
    Last Post: 11-01-2004, 06:48 PM
  4. New header?
    By Robs89LXi in forum Trading Post
    Last Post: 02-17-2004, 09:11 PM
  5. Need a Header
    By K-MOD in forum Trading Post
    Last Post: 02-17-2004, 09:07 AM
