Page 3 of 3 FirstFirst 123
Results 51 to 55 of 55
Thread: '86 Hatch to join the ranks
  1. #51
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    Re: '86 Hatch to join the ranks
    Quote Originally Posted by SkateK610 View Post
    So if emissions are not a big concern, does this effect the cars performance much?
    I also opened up the black box and it seems like everything is as it should be, it looks like the day it was put in the car.
    My black box looked exactly the same as yours, but my A/C idle booster was not working (not a big deal anyway). It turned out one of the small solenoids inside the box was dead (there are two similar ones, the other is for the distributor advance -extra advance it seems). I harvested a couple good ones from the junkyard (one for spare) and got it fixed.
    It's not a big deal. EGR helps to reduce pinging, but some guys get rid of it entirely. The stuff inside the black box can look fine, but still fail. The EGR troubleshooting section helps you find what is failing and replace it.
    x2. No need to fix it -other than pinging- unless you have to do smog/emissions.
  2. #52
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    Some more news, last night driving home the dash lights went out, where to start...
    Your Honda, isn't my Honda.
  3. #53
    start by replacing the dimmer switch on the dash.
    Is it only the dash lights? headlights and turnsignals come on?
  4. #54
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    Headlights and turn signals work, dash lights license plate light and the running lights are out. I check the interior fuse box # 15 and 14 arnt blown, but there is some rigged up system going into #14, its a red wire from a harness split into a wire with a metal tab stuck into the #14 with the fuse also in there
  5. #55
    Jan 2011
    1986 Lxi Hatchback
    Chicago
  1. lovein the site just had to join
    By 2genforlife in forum Newbie Introductions
    Last Post: 11-30-2010, 10:03 AM
  2. lower ball join replacement
    By dosh8er in forum 3geez Accords
    Last Post: 09-20-2003, 08:29 PM
  3. engine everyone join in.
    By 89chaosaccord in forum General Engine Swaps
    Last Post: 05-25-2003, 03:42 AM
  4. Guests with 86-89accords should join the 3geez board
    By Mike's89AccordLX in forum Classic Honda Community Chat
    Last Post: 10-27-2002, 08:27 PM
