Results 1 to 25 of 39
Thread: stalling issue
    Jan 2011
    Oahu, HI
    stalling issue
    Hey, I have an 86 accord dx all stock with a new carb it has 157K miles. Ill post a pic later.
    Anyway I recently just got it and found there was an issue.
    I looked around and have some idea what it might be but wanted to see what you guys think.
    it has an issue with stalling after I drove it for about 30 min in about 80F weather and then parked it for 30-45 min and when I started back up the rpm would be iradical going up and down and unless I press on the gas the car stalls. Once I'm in gear and driving in 1st or 2nd without pressing much on the gas its driving a little shaky which is pretty normal in 1st but not in second. After driving it for a little while and picking higher speeds on the highway it stops stalling and idles fine. I have yet to do some more tests and figure out the exact cause.
    From what I've read some people say to clean out the choke plate (I'm not too sure what it looks like or how it even works) but they said spray some carb cleaner the bronze looking tubes on the carb.
    Another I remember to check the coolant level.
    And I think someone said it might be the fuel pump on it way out.
    I was thinking maybe change the fuel filter? Any suggestions?
    Thanks
    LXi User Buzo's Avatar
    Dec 2010
    North of Mexico
    Re: stalling issue
    Quote Originally Posted by poison2003 View Post
    Thanks
    Let's start with the easy ones.
    Check if there is fuel odor when you end your 30-45 minutes drive.
    The fuel may be over flooding the engine.
    Jan 2011
    Oahu, HI
    Re: stalling issue
    Quote Originally Posted by Buzo View Post
    Ill try it. And forgot to mention it is a manual. So far after I've been driving for a while hasn't happened but the conditions aren't the same since its a little cooler outside everytime it happened it was hot and sunny outside.
    Jan 2011
    Oahu, HI
    Re: stalling issue
    this time ive been driving it for small distances and while the engine was at running temp i parked it grabbed something and about 2 min later tried to start the car it happened again, i wasnt able to check under the hood because i was in a hurry but i did try a few things.
    i tried to drive the car in high rpms in second gear and tried going through gears if it would help i went up to 4th and yet nothing helped. what did happen this time is i had to stop 4 times each tight i released the clutch it went straight to 0 and i had to crack the engine again.
    I noticed that to start it i had to pump the gas while i was turning the key to start it. after about 2-3 miles later and 4 stalls it finally went back to normal. its quite noticeable when its normal again because the car at low rpm of about 2k doesnt shake when i apply a little bit of gas.
    any suggestions what it could be are very welcome. I drove the car all this week and this is the only time it happened about 300 miles later
    Jan 2011
    Oahu, HI
    Re: stalling issue
    any ideas or other tests i can run to figure this out?
    its hard to tell because it happens so rarely but it would be very frustrating if i had to be in stop and go traffic and i had to restart my car everytime i took it out of gear or stopped pressing on the gas
    Re: stalling issue
    Rebuild the carb.
    Jan 2011
    Oahu, HI
    Re: stalling issue
    Rebuild the carb.
    its a brand new carb
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Re: stalling issue
    try another dizzy if you can. It sounds like the problem i had with mine. just crazy ass random idle and stalls. You can try cleaning it out, but it didn't help mine. Look up the manual and test stuff on it if you dont have a replacement handy.
    Re: stalling issue
    Like brand new from Honda or newly rebuilt by someone else?
    Jan 2011
    Oahu, HI
    Re: stalling issue
    like brand new its got no grease or anything on it, it even shines i dont know exactly if it from honda but it is new.
    i adjusted my rpms and what not im gonna see if it happens again it could have been just that but we will see
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: stalling issue
    Anytime you put on a new carb on, you should change out the fuel filter(s). Especially the age of these cars & for warranty.... I doubt you want to change the sock cap in the fuel tank, but at least change out the filter on the frame rail behind the L.R. tire. Carb models have one under the hood too, not so sure on F.I. models.
    Dec 2010
    North of Mexico
    Re: stalling issue
    I still think a long crank time is caused by fuel flooding. Do you notice strong fuel odor when you are crancking it after a sudden shut down?
    Re: stalling issue
    Far out. Where did you get it? More importantly, how did you adjust it when you put it on?
    Jan 2011
    Oahu, HI
    Re: stalling issue
    ill check the fuel filters prbly next weekend.
    its not really long crank its just after it dies (99% of the time when im in traffic) when i restart it i have to give it some gas while i turn the iginition. i tried checking for fuel odors but im only able to do it when i park somewhere and by that time it usually goes away.
    I got the car with everything done to it the guy said its a new carb and it looks like a brand new carb. when i adjusted it i just messed around with the throttle screw
    Apr 2007
    NW Arkansas
    Re: stalling issue
    check your grounds too. If your still only using stock grounds add a couple. it makes a difference i promise
    Re: stalling issue
    IT IS more likely some control device outside the carb which affects linkages oh the many many of those on that carb...
    Even a new replacment carb needs to be set up for the car. First things to check is the choke and fast idle hardware. Then make sure the secondary control valve is not hanging the sec linkage open slightley at idle.
    VAcuum leaks, make sure there are none.
    Re: stalling issue
    I agree with Roodoo, but I think you also have carb setup issues too. Carb setup, unfortunately, is more art than science. PO probably had some external control going out. He or she bought a rebuilt carb (I'd be very, very surprised if it was a new carb) hoping it would fix the problem. They didn't tune it properly and reused all the old controls. Not only did the original problem remain, but new problems were introduced. The carb was expensive enough, so they just sold the car instead of paying more to get it sorted. I'd check the float adjustment, choke adjustment, and then check all the little solenoids and dashpots to make sure they are working properly.
    Jan 2011
    Oahu, HI
    Re: stalling issue
    as a side question after i drive my car and park it and lets say an hour later i get it when i start it is it supposed to high idle and warm up again? (ofcourse if it cooled down enough) since when i first start the car it warms up fine on cold start but after that through out the day i usually end up holding the gas a little after a start it to prevent it stalling out. (prbly for about 30 sec or so) Since i live in hawaii it doesnt get cold and the coldest its been is about 55F
    Dec 2010
    North of Mexico
    Re: stalling issue
    I don't think an hour or two are enough for the car and choke's linkage to get back to the morning-cold position. Mine does exactly the same thing as yours.
    And just to close my comment on the fuel odor, you don't need to search for it. It is so evident that as soon as you open the drivers door after a short drive, it will hit your nose. So fuel flooding is not your problem.
    Re: stalling issue
    I'm still thinking carb tuning issues here. It sounds like your carb is good, just need to sit down with the manual for a few days and figure out how to optimize everything. Please don't go in without the manual or you will make a fantastic mess and be towing it to a dealer to get it sorted out. I'm speaking from personal experience here.
    Jan 2011
    Oahu, HI
    Re: stalling issue
    yeah so far its been driving pretty good havent had any issues since i adjusted the idle. i guess when i take it out for a little longer this weekend will find out if its still having same issue.
    i do have a manual in pdf which was on my phone at the time when i was adjusting the carb but i didnt have the cable to drop it off on the computer and since i was at a friends house we didnt have access to the manual. Now i know the manual is on 3geez wiki which i can access anywhere.
    If the problem keeps happening ill have to take my time and adjust/lubricate everything i need properly.
    Re: stalling issue
    There should be lots of tests for all the little electric and vacuum controls on the carb. I would test them all. Good luck.
    Jan 2011
    Oahu, HI
    Re: stalling issue
    It happened again. This time I think I realized why since I've been doing about the same routine for a couple of weeks.
    I started the car and I was ina little rush and started driving it before I warmed it up and when I took it out of gear it died I thought at first it was normal but then I started it up and the same symptoms as above started happening. More shacking at slower speeds and not holding the idle
    Also noticed that if I pump the gas a couple times before I start the vehicle after it stalled it starts right up but doesn't hold the idle aswell. Could it just be one of the fuel filters?
    Dec 2010
    North of Mexico
    Re: stalling issue
    Look at the carb's glass window. If there is lack (or excess) of fuel, it will tell you. The fuel level must be right in the middle.
    At least mine, it doesn't care if I start driving it right away, even at -10 C weather. Actually it works better since the shock is still on. Then it stalls in the first red light during my drive to work, but it gets normal (900 rpms) after 10 minutes. So don't feel guilty for not waiting for the car to warm up.
    Jan 2011
    Oahu, HI
    Re: stalling issue
    Well just checked what you aid and its over the middle line and when you turn the engine over it goes even higher
  1. Stalling issue ('87 Accord LX)
    By Snowfox in forum 3geez Accords
    Last Post: 08-05-2012, 11:34 AM
  2. Replies: 19
    Last Post: 01-15-2007, 04:12 PM
  3. Stalling Out
    By dj99 in forum 3geez Accords
    Last Post: 12-05-2004, 11:47 AM
  4. car keeps stalling
    By XxDark_AccordxX in forum 3geez Accords
    Last Post: 11-05-2004, 12:17 PM
  5. Almost Stalling
    By X-Lr8 in forum 3geez Accords
    Last Post: 02-27-2004, 09:56 PM
