Results 1 to 25 of 42
Thread: new motor mount
    new motor mount
    I just discovered my almost new front motor mount is cracked, this is about the third one in i've bought in 10 years, I guess they are just a bad design, but anyway I've deceided to make my own, I know someone in Minnesota who will do some aluminum sand castings for me, so I'm going to make a master mold of an adapter to use an energy suspension engine mount,
    this is the mount I'm going to use,
    I have a large chuck of ash and I'll start machining it into a mold as soon as I can get all the measurements figured out
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Re: new motor mount
    Looks good
    SE-i Sedan 5 spd
    Re: new motor mount
    There must be a reason you're burning through mounts like that. Doesn't seem to be a typical problem.
    Re: new motor mount
    all the mounts are new, i just think the quality went down to crap on the aftermarket ones, a lot of people here have had problems with that hydraulic mount, I've got to figure out the height from the cross member to the flat where the motor mount bracket sits, once i have that i'll sketch out the basics of the bracket on paper, figure the measurements , and start making the mold out of a block of hard ash I have, once the mold is perfect, i send it off and get two cast aluminum brackets back. then they get machined for the energy suspension pieces
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: new motor mount
    This is just me playing devil's advocate here, but your mount may be cracked from sitting? More power to you on the custom mount, because your right, those hydraulic mounts suck, just offering a suggestion
    '89 SE-i Coupe
    Awaiting Garage
    Re: new motor mount
    can someone identify if there is a difference between the dx and the lxi mount? advance says they are two different mounts, different prices, if the one in the car is wrong, my engine is sitting wrong, I need to find this out before i do all this work and find out it's wrong
    Feb 2004
    89 accord lxi
    down by the bay
    Re: new motor mount
    The front mount?
    '86-'88 the mounts were all the same regardless of trim level or auto/manual. '89 is where it gets weird with 3 different mounts and 2 different brackets.
    There's a thread here: https://www.3geez.com/forum/showthrea...ighlight=mount
    Re: new motor mount
    Quote Originally Posted by Strugglebucket View Post
    The front mount?
    I went and measured two at advance today, both are supposed to be 86, one is from a carb, and one from a FI car, both are different, for some reason even the bolt centers are different, I though they all had the same cross member, my engine sits high on that corner which makes me suspect I was sold an 89 or something
    Feb 2004
    89 accord lxi
    down by the bay
    Re: new motor mount
    The older bracket and the dx/lx for all years was made out of stamped metal. The '89 lx-i had a solid cast bracket, with a step machined out of the auto trans bracket (the auto mount was about ¼" taller).
    Re: new motor mount
    right, I have the stamped bracket, I suspect I may have an lxi mount, this would explain why the exhaust would bump the cross member slightly, I have now what I suspect is the correct height, I'll put together a couple of blocks of wood which are the correct height with a bolt in the center and see if the engine drops down. I can't even do anything with the exhaust until I know for sure the height is right.
    Re: new motor mount
    If I can get the height of the base right, I'm going to make my own mount, I decided to use a heavy aluminum base with a round machined out aluminum piece, I'll suspend a hardened bolt in it with a washer for a safety interlock, then fill it with urethane compound, when it's hardened it will get another piece with a hole in the center bolted over it, this will prevent the mount from pulling apart, this should fix the issue of it breaking once and for all, I was going to cast something, but after finding out about this compound that is available, I'll make my own
    Nov 2000
    Re: new motor mount
    What I would like to see are the front fluid filled mount and the rear lower transmission mount (you should replace both together) in a form that is both more durable and still controls engine vibration. These engines have no balance shafts, as the 1990-on Accords have. I pretty much know to replace mine when the contents of my glovebox start rattling at stoplights. I am on my third set and I am pretty tired of replacing them as well!
    carotman's Avatar
    Montreal South Shore
    Re: new motor mount
    I also got tired of my front mount breaking (I got rid of the dogbone)
    Let us know how this turns out.
    I need these parts!
    Nov 2000
    Re: new motor mount
    Does eliminating the torque mount (dog bone) do anything positive? Just wondering.
    carotman's Avatar
    Re: new motor mount
    Quote Originally Posted by DBMaster View Post
    Not at all. I had to remove it in order to install my Edelbrock Intake.
    I need these parts!
    Re: new motor mount
    Ok it's almost done, I need to get the liquid urethane to fill it now,
    this is the base of the mount, I cut this square piece roughly to shape before machining it,
    this is with the center bored out
    roughly finished mount the base still needs to be attached to the mounting plate,
    this is the guts of the mount, the center section suspends inside of the outer case, the heavy piece of the steel section sticks out about a half inch, this is what the motor mount bracket sits on, I need to make a collar to fit in the top with a setscrew, this will let me exactly center the center piece and adjust the height perfectly, once it's adjusted right, liquid urethane gets poured in the outer case, in a couple of days, the collar comes off, and the center section will be bonded permanently into the urethane, there's a gap between the center section and the top, to allow for movement. the reason for the washers is to make sure the mount can't come apart.
    Re: new motor mount
    a few more pictures, I'll get some better ones tomorrow, I made the collar piece, this slips into the top of the mount, and centers the center section, as well as sets the height while the urethane is curing, once it's fully cured, it removes, leaving the center piece exactly set in the correct position.
    Re: new motor mount
    does someone have the correct compressed height of the front mount for the carb car? I can adjust the center section of this mount before the urethane is poured, I also want to make sure I got the center to center of the mounting bolts right.
    Re: new motor mount
    ok I'm pissed, I based my height measurement off of an actual mount at advance, Cygnus just got me the compressed height of 73 MM, this means my mount is almost exactly 1 inch too tall, it's also the same height as the one in my car now, this is going to throw off a lot of my measurements, i used a small height gauge to measure the one at advance, i figured it might compress slightly, but it's not going to compress an inch, Now i have to cut an inch off of the height of my motor mount center, and redrill and tap the holes that hold on the top, I always wondered why my motor looked cockeyed
    AZ
    Re: new motor mount
    so tim, why is it that you start a new thread for each one of your projects? it would seem better if you just added them all into one thread like a normal sane person, but i guess if the glove doesn't fit you must acquit right?
    dead white and blue
    Re: new motor mount
    it's a project thread, why do you have a problem with my thread? it's a technical thread.
    Nov 2000
    Re: new motor mount
    Personally, I want to know how your mount is performing a few months after you install it. I would like to know how the vibration level is compared to the fluid filled OEM mount.
    Re: new motor mount
    the urethane comes in three durometers, the softest is like a factory mount, the middle one is between a race mount and factory, and the third is full out race. they recommend the middle one for street use, they transmit vibration in the same order, third is the harshest first is the least harsh, when I can order the urethane i'll post more details, this is the same stuff they make energy suspension mounts out of. basically i'll be suspending the center pin with a big washer and a hardened bolt as a mounting stud in the urethane, the collar piece I made keeps it perfectly centered and at the exact right height, the collar will get coated with a release compound so it comes out, it sits for a week, and the collar comes off. this leaves the center piece locked into the urethane. the washer is to give it a good purchase on the urethane, and it's also larger then the opening of the mount, this is a safety to prevent the pin from ever coming out.
    carotman's Avatar
    Re: new motor mount
    This is awesome work there Tim!
    I need these parts!
    AZ
    Re: new motor mount
    oh it's a great thread don't get me wrong it's just that you have about a million different things going on with the car, but most people would consolidate them into one thread with updates on each specific project. that was the intent of this forum to be a place for project (read car) threads. just saying.
    dead white and blue
  1. useing a rear mount to replace your front motor mount
    By Civic Accord Honda in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-24-2008, 06:14 PM
  2. Motor mount fix
    By sunderland in forum Restoration & Custom Fabrication
    Last Post: 11-22-2005, 09:56 AM
  3. Bad Dog Bone(motor Mount)
    By HondaBoy in forum Performance
    Last Post: 05-11-2003, 09:24 PM
  4. Motor mount
    Last Post: 02-09-2003, 07:20 AM
  5. front motor mount
    By franks89sir in forum 3geez Accords
    Last Post: 08-19-2002, 10:10 PM
