Ok I got the ground controls in today. I have never seen a coilover before so I have to ask some questions. I suppose the adjuster threaded doey goes toward the bottom and not at the top towards the cap. But the little metal disc supplied with the koni's (the thing that holds the spring up) and the threaded piece don't sit right together. I found out that if I reverse this metal disc on the shock and put it on upside down the ground control adjuster sits more balanced and more evenly distributed. Does anybody have a clue about the problem I'm talking about? Oh yeah what are the rubber orings for?...thanks
