I just got done installing a set of H4 conversion headlights into my Accord. I got the whole setup from EGay, it came with the sealed beam conversion housings, the HID bulbs, wiring, ballasts, and mounting brackets.
The light housings are really good quality, alot better than I expected. They are actually glass and are well built. It's a 35 watt, 8000K bulb bi-xenon beam setup. I ended up having to take my front bumper off to fit all the wiring where I wanted it underneath the headlamp assemblies. I ended up mounting the ballasts behind the front bumper assembley, and I have enough slack in the wiring that the housings are able to flip up and down just like they should.
These housings are pretty well designed too. There is minimal side glare, and I have them properly adjusted so they wont blind other drivers. (Believe me, I tested it driving by in my friend's car).
All in all it took me about 3 hours total to swap over to the HID setup. Considering I was working on the ground, in the snow, and never having taken the front bumper off before, I think that I did pretty good!!!Someone more experienced with these cars and having lift access could probably have it done in about an hour.
Here is what the kit looked like when I opened it up.
Here is the beam pattern of the lights with the HID bulbs. I adjusted them down a bit to minimize glare for oncoming traffic.
Here is how they looked while testing them out. I still had the front bumper off in this picture as well.
All in all, I think that this is the absolute best mod I have ever done, and probably will do to my Accord (Unless I turbocharge it!) and it is well worth the $80 that it cost me.
