Results 1 to 6 of 6
Thread: fuel line size?
    DX User 86dxhatch's Avatar
    Oct 2010
    86dx hatch
    Venice, FL
    fuel line size?
    Does anyone know offhand what size fuel line an 86 carb model has?
    I'm installing the 32/36 weber and have already purchased the following...
    -redline kit
    -Adj.FPR
    -fuel pressure gauge
    -fram clearview
    -high-tack gasket sealant
    -assortment of vac plugs
    Now I need to get the fittings for the Adj.FPR. One 3/8-1/8 reducer and two 3/8 barbed threads for fuel line, but can't tell by looking if its 1/4 or 3/8.
    Just want to prevent a trip to the parts store while doing the swap. Thanks
    Oct 2010
    86dx hatch
    Venice, FL
    Re: fuel line size?
    After some searching I figured out that the line is 8mm.
    So, should I be fine with some 5/16 hose, or is this what the 3/8 Mopar heater hose mentioned in Weber threads is for?
    Isn't the port on the Weber 3/8?
    Re: fuel line size?
    I'd be surprised if you found metric fuel line anywhere but the dealer. I'd just get the closest standard size and make it work.
    Oct 2010
    86dx hatch
    Venice, FL
    Re: fuel line size?
    I know 5/16 is smaller than 8mm so, what would be a better fit, 3/8 or 5/16?
    What size fuel line have others used when doing the Weber swap?
    As this is my only transportation, I would like to be able to get all of the correct parts I need beforehand. The autozone is 7mi from my place and I'd hate to have to walk there becuase of somthing like fuel line.
    cygnus x-1's Avatar
    Chicago area
    Re: fuel line size?
    Quote Originally Posted by 86dxhatch View Post
    5/16" fuel line is a direct replacement for 8mm. It would be a good idea to mock up the entire fuel system to the carb before you actually do the install. And don't forget the little things like hose clamps and such.
    C|
    Jun 2010
    1989 LX Auto, Weber 32/36, MSD Blaster 2 Coil, Paceshitter header, full 2.25" exhaust.
    Re: fuel line size?
    The main fuel line is 5/16", but if you want (or need) to keep the evap can, you'll also need a bit of both 1/4" and 3/8".
  1. Fuel line size
    By thegreatdane in forum Performance
    Last Post: 01-11-2009, 04:11 PM
  2. Vaccum line size??
    By great86er in forum 3geez Accords
    Last Post: 01-28-2005, 01:04 PM
  3. hepl cannot got fuel line off fuel filter
    By 88vert in forum 3geez Accords
    Last Post: 02-04-2004, 09:20 AM
  4. fuel line frozen?
    By dirty89lx5sp in forum 3geez Accords
    Last Post: 01-30-2003, 06:58 AM
  5. Fuel line?
    By CoAsTeR in forum 3geez Accords
    Last Post: 11-19-2002, 10:53 AM
