Awesome Very awesome. I'm jealous of the crank!
That looks like a awesome setup! Little more add ons to be up to OBD II level? lol
Not trying to be negative, but don't care for the butt connectors (wire splices) you used. Butt connectors are OK where the wires aren't exposed to the elements. The prefered method is to solder them wires together & used some heat shrink tubing on the joint.
They sell butt connectors that your crimp which are a little more expensive. You heat up the ends & seals the joint.
x2
yea i know, the wires and splices will taken care of tho, heat shrink, wrapped in conduit, etc...
I did the same thing with my initial setup. Easier to butt connect everything and make sure you wired it all up right before you go bundling and soldering all the wires... I don't know how many times I had to rewire this or that because I had something backwards. Was glad to have the butt connectors from the get go.
i really need to get back to work on this, lol...
Yes!
I done. It werx now! kthnx.
VIDS! How's the tune going on that guy? Using the default map that comes with it? Or had a chance to advance it up yet?
woo
I wana see this in action buddy. It's time you pull out that camera for us
88 lxi:
I feel like this is old news for some reason.
mounted...
dizzy blockoff plate...
Woot!!!!
Sweet. So this allows you to tune your ignition timing how you want correct? And you are the first accord with ford parts that I've seen lol. Fonda accord
88 lxi:
anybody know what wire i hook the 'tach output' wire to, so my tach works. and any ideas to get the fuel pump going, other than running a switchable / 'hot' wire from the ignition.
there has to be an output from that box somewhere that you can hook to the rev counter. you can also use the stock carb accord fuel pump relay as it uses a rev sensor to turn on the pump i believe
yea but i dont know what wire is the rev counter, and i dont know what wire/wires to use for the fuel pump relay.
i guess start the car and hook the rev counter wire to random wires till it works accurately lol. i dont think you can blow up the rev counter by doing this
