Results 1 to 25 of 27
Thread: No dash, side markers
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    I was driving one night and all of a sudden, lights out!
    Headlights and turn signals work, but all of the 1 click on the light switch is out. I check the interior fuse box # 15 and 14 arnt blown, but there is some rigged up system going into #14, its a red wire from a harness split into a wire with a metal tab stuck into the #14 with the fuse also in there
    Heres the wire
    http://img138.imageshack.us/i/021111125700.jpg/
    Any other fuses to check?
    Your Honda, isn't my Honda.
    Quote Originally Posted by SkateK610 View Post
    Heres the wire
    have you swapped another fuse into 14? 15 isn't used. looking at the schematics now
    it has to be between the 40 amp under hood fuse and fuse 14 under the dash, if the 40 amp fuse was blown, you would have no headlights. the side markers and the dash lights are all on 14, i would say combination switch, but it was working before, and if they tried to feed power directly into the circuit, the dash lights would never turn off, did they come on by themselves when the switch was turned to the first position? it seems someone was trying to power something off of that circuit, possibly a set of fog lamps or driving lights etc.
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    Re: No dash, side markers
    Before they went out everything worked as it should, dash/exterior lights, and the glove box light
    Also the clock works but it doesn't dim like it should
    try swapping that fuse and if it doesn't work i'll let you know how to test the switch, the 40 amp fuse goes right into the light switch, then it's split by the switch into 4 fuses for the headlights, and fuse number 14, and one more fuse i think for the running lights, fuse 14 is the fuse for all the dash lights etc, the clock won't dim,because the 12 volt signal to tell it to dim also comes from fuse 14. do you have a meter? if you do, find fuse 14, turn the light switch on to the first position, now you should have 12 volts on at least one side of the fuse, if you don't, the switch is bad. check for voltage with one meter probe on ground, and the other at each side of the fuse
    I don't think sidemarkers should have been affected. Were they out before?
    sidemarkers are on the same circuit as the dash lights, fuse 14, the regular running lamps are a different fuse, everything is from the 40 amp fuse under the hood, but if it was blown, the headlights wouldn't work
    i read his thread again, and since he said the fuse never blew, i'm thinking it's the switch, the wire attached to 14 sounds incidental, probably from an old aux lamp setup, I think russian kid has a really good writeup on fixing the switch, the contacts just get dirty and quit making contact
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    Which switch would that be, thanks for the help
    well the light switch, if you turn it to the first spot and the lights don't come on, and the fuse is ok, but the second spot and they come on, it might be the switch, do the lights go up on their own?
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    Well, first click nothing, second click headlights, thats it
    do the lights go up and down on their own? strange because the module uses a signal from both the headlights and parking lights to trigger the headlight motors, if there is no voltage between ground and either of the fuse terminals on 14, with the switch on, I would suspect the switch , it's a single heavy wire into the switch for both the headlights and the other lights, it's split after the switch, since the headlights come on, everything from the 40 amp fuse up into the headlight switch is ok, it's after that point, possibly inside of the switch
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    The headlights work just as they should
    strange, it has to be in the switch is 14 isn't blown, come to think of it i think the headlights get their signal from another fuse for the running lamps, do the running lamps come on on the outside of the car?
    everything is on fuse 14, the output of the switch on position 1 goes to fuse 14 and is distributed from there, check for voltage at the fuse with it on and trace back from there to the switch, have you checked the plugs on the back of the fuse box? if the switch is good power may not be making it from the switch into the fusebox
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    running lights dash, glove box, tail lights, and license plate dont work
    i sent you a pm if you have aim get on aim my SN is lostfor
    x2 on the switch. The combo switches are failure prone.
    he's going to check it tomorrow but he said the fusebox was loose, it could be a connector plug isn't plugged in all the way
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Couldn't the dimmer box under the wheel cause this?
    just throwing it out there
    Quote Originally Posted by Demon1024 View Post
    Yes, and it's easier to check than the combo switch. Nice catch.
    it's not just the dash lights, it's all the lights off of switch position one, including the running lights on the car, also the clock doesn't dim, this is a direct 12 volt signal from the headlight switch,not through the dimmer box, basically everything off of fuse 14 is out, dimming circuit or not,all he has to do is check to see if there is voltage at fuse 14 with the switch on, voltage into 14 is directly from position one of the switch, everything past that is a branch off of it. no voltage, something is bad between the main power feed coming into the headlight switch, and that fuse, since the headlights work and retractors work, this means the 40 amp main fuse is good and power is coming into the switch
    Apr 2007
    NW Arkansas
    i'm pretty sure i had to rewire my running lights when i took this thing out. Who knows, it wasn't the problem (turned out to be a dash ground) i messed with alot at that time
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    How would I go about checking the switch?
    Probably the simplest is to swap in a junkyard combo switch and see if that fixes it. Otherwise, you can download the ETM from the wiki and start testing voltage outputs.
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    Fixed, the wiring in this car has been completely rigged i took apart the steering cover and found a loose wire, reconnected and made a new piece to go into the fuse and all is good.
    Jan 2011
    1986 Lxi Hatchback
    Chicago
    Now so I dont start a new thread on my electrical woes..
    Another problem ive had since i got the car is the hazard switch doesn't work, when i flick it the turn signals wont work for a bit and i have to move the stick back and forth for them to start working again.
    Where to start
    Jun 2010
    88 accord lxi coupe 5 speed
    San Diego
    I think that's normal, my hazard lights only blink when I enable my turn signal and the hazard light switch.
  1. side markers
    By DeeJay in forum Interior & Exterior Care
    Last Post: 09-11-2003, 01:38 PM
  2. Clear side markers
    By c20v6turbo3rdgen in forum Interior & Exterior Care
    Last Post: 07-09-2003, 05:23 AM
  3. European Side Markers
    By !(>..<)!85AeroAccord in forum Interior & Exterior Care
    Last Post: 03-24-2003, 05:40 PM
  4. Side markers !
    By GreenMachine in forum 3geez Accords
    Last Post: 07-16-2002, 02:48 PM
  5. Help with removing side markers
    By pimp86LX in forum Interior & Exterior Care
    Last Post: 05-13-2002, 05:25 PM
