I hope that how the less then symbol goes, I don't exactly remember. Anyways I swapped in new moog front upper control arms and tie rods. I have an order in for the bushing sets and I wasn't sure about the rear control arms. the car squeaks like crazy and the passenger front seems extra loose up front. When you hit a rough patch of road the car really does wander wherever it wants to go and its hard to keep in the lane around a turn under these conditions.
Today I go out and install the studs since Im planning a lot of snow on my way to work for the next few days and the rears are past the wear indicators. Its been about 3 weeks and just about a 1k miles and they have nothing left.
The rear upper ball joints actually rack inside the housings like you can move the joint around while its bolted in and it clunks real bad. I'm sure that means its bad but is it worth a set of those spc adjustable types since I'm about 2.5in lower then stock? Also with that front passenger side. I still need to do the lower ball joints and all the bushings since they have about 275k on them. What else could cause the crazy out of control driving? When I try to push and pull the tire off the ground it feels tight, no clunks or noticeable movements. I have the 2nd gen arms swapped in, all washers to the rear of the car. Thanks for the help. Im going to start pricing out the rear arms and see if its something I can do tonight before I leave.
