^Sellin a dream..
The motor had around 150 thousand on it.. Im going to swap out the long blcok on it i think. Not sure yet... Gotta make sure....Popped the hood and u can hear it pretty bad.
So i gotta look and see what i can get a long block for at the jy. The one i put in it i got for 75 bucks in northern kentucky a couple years ago . but im far from there now in michigan... so i gotta make calls tommorow ..
SUCKS BIG TIME THO
All i need is a cherry pic. And a truck to get the motor here
b-swap...no one here has been able to swap one...prove us wrong![]()
we just need motivation
If i could blow 5 grand on it . Id be on it.. What do the mounts go for ?
Are you guys thinking of putting a b20 in it with a b18 head and pistons?
Im B20 stupid.. the axels would cost big bucks
I could just imagine the amount of wiring and so forth needed to get it running right with the v tech. But is it possible to do all your own gauges and just a ecu to run ? Im clueless but i think its actually more simple than what everyone thinks it is as far as getting the wiring right. I think with the right understanding of how the wiring goes the easy part it just swapping and adding wires form what i read in a someones thread.
I dunno but it would be nice for sure and would suite this cars size with having the power a b20 block an bring u. Alot of work tho but would defiantly be a satisfying investment
yeah its starts to get easy if you know what needs to be connected to the ecu so it can run
By williamsmchad at 2011-05-04
I Got my motor and it was in terrible condition. Like is sat out in the cold and rain for a season....
So i stripped her down and im going to just swap over my intake and repaint the exhaust manifold And cover. Its in alot better condition than the one i got.
I stripped the JY motor down to the long block . I just degreased the whole block then scrapped on it with a couple flat heads a couple times in some bad areas .and wiped it down twice and reshot it with degreaser for the night. There is a lot of stain on the head around the plugs that i wanna hit again and clean it up better .
I didnt get any paint yet.
Auto zone only had like red black and blue in the high heat Paint.. I Need Black and Silver .
I grabbed a new valve cover gasket tho .
Im leaving all the brackets on the block and just paint bolt bracket and all. Including my wire harness clamps that are all rusty .
I Got as far as the wire harness on the motor im pulling out. And a couple ins and outs. But if forgot my jack stands and i dont make messes. So the sun gave me enough work light....
So tomorrow im back on it. I should have her in and running and looking good on Sunday. Just to make her special
I cant wait to pull it tho. I got to rent another engine hoist so im tryin to get it to a in and out thing. I might have to have it for two days because i have to do the radiator too and im going to pull it with the motor out and i want to clean the engine bay as good as i can,
~~~~~~~~~~~~~DAY 2 CLEAN UP AND PAINT ~~~~~~~~~~~~~~~~~~
By williamsmchad at 2011-05-06
High temp paint silver looks great .. Painted a much dirt off as i could ..
The before and after you will be able to see all the little stuff i got..
Looking good and clean tho...
Tomorrow im finishing up building the motor . Then pulling out the old motor and cleaning the rest of the engine bay out and tranny. I want to paint the tranny but im leaving it in the car we will see what i can do. I have a whole can of black maybe il just paint it black i donno...The silver paint comes out looking great tho.
CHEERS
Damn!
Its amazing how a clean up and paintjob can look so damn tasty.![]()
By williamsmchad at 2011-05-07
Looks like a whole different engine!
So clean!
Keep up the good work!
By williamsmchad at 2011-05-11
New motors in and looks good...
A couple minor things . . .. Code 7 on check engine light....What is it ? ?
And the damn thing wont stop idling at 2500 Every thing is were it is supposed to be...Not sure why yet . . .Any ideas?
wow looks good
It does indeed look good. keep up the good work![]()
07 LED FLASH(s) 85-98 Accord
TP Sensor (Throttle Position)
defective circuit or unplugged / defective sensor
i found this hopefully it helps. prob exlain the 2500rpm idle too. lookin great btw
