Page 1 of 4 1234 LastLast
Results 1 to 25 of 94
Thread: weird noise
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    weird noise
    ok so i was driving and then i lose power and my lights dim and the car wont idle at all and i have to keep on the gas to keep it running and then about 20 second later it will stop.
    this is the noise it started to make except it was a whole lot louder in person than on the video.
    and then at the end of the video u can hear it stop
    http://www.youtube.com/user/accord19.../0/RKpinU6BWWA
    alternater maybe???
    i just wanna say thanks for the help in advance
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    Re: weird noise
    its very possible, take a multi meter to the battery see if its got about 12V. with the car on it should be around 14.1-14.4V.
    3Geez resident body man
    Owner of Wreck-less auto body
    May 2010
    1986 accord LXI
    Chicago Il
    Re: weird noise
    with the car off it sits right around 12.5
    1989 Lx-i Hatchback
    Jackson, NJ
    Re: weird noise
    ok sounds good. whats is it with it on? doesn't sound that bad in the video idk is it bogging down too?
    May 2010
    1986 accord LXI
    Chicago Il
    Re: weird noise
    14.4 with it running
    and its a 1986 accord lx-i 4door 5-speed
    May 2010
    1986 accord LXI
    Chicago Il
    Re: weird noise
    ohh and also it does like the loudest screch like a belt is slipping sometimes and yes i bogs when it screchs
    1989 Lx-i Hatchback
    Jackson, NJ
    Re: weird noise
    wouldn't be the alt. its running fine. if it feels like its bogging down mashing the gas, possibly the cat converter is clogged / junk.
    May 2010
    1986 accord LXI
    Chicago Il
    Re: weird noise
    when i first head the noise it sounded like i spun a bearing or something it was that bad
    May 2010
    1986 accord LXI
    Chicago Il
    Re: weird noise
    but the noise is like spratic and when it does do the noise it runs bad and then it will run fine
    i dont think its the cat i a hole in the flex pipe so if the cat it blocked then it would just go out there
    May 2010
    1986 accord LXI
    Chicago Il
    Re: weird noise
    ohh and btw the car only has 63,000 original miles
    Re: weird noise
    water pump or power steering pump bearing going? if it was it would bog down the engine and rattle
    May 2010
    1986 accord LXI
    Chicago Il
    Re: weird noise
    would those be intermittent?
    it only happens some of the time i drove to school and nothing at all and then when im coming home it does it for about a min and then fine
    May 2010
    1986 accord LXI
    Chicago Il
    Re: weird noise
    but did u hear at the end of the video the screching stopped
    LX User 1813mdw's Avatar
    Nov 2010
    Jackson, Michigan
    Re: weird noise
    pull the powersteering belt off and see if it still happens; i've also seen ac compressors do this before seizing up all the way. GM 3100 and 3300's were notorious for this and they even sell a bypass pulley for them(GM; not 3gees).
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Re: weird noise
    check your distributor and T-belt tensioner.
    May 2010
    1986 accord LXI
    Chicago Il
    Re: weird noise
    Quote Originally Posted by 1813mdw View Post
    would those be intermittent cause some times its totally fine and other times its terrible
    Re: weird noise
    It's hard to hear the noise in the video. Is a belt slipping? How old are your belts?
    Re: weird noise
    If your alternator bearing is going out, it could put out voltage just fine, but still make horrible noises. You can pull off all the belts and rotate things by hand to see if there is roughness or play. If it is intermittent though it could be hard to tell.
    May 2010
    1986 accord LXI
    Chicago Il
    Re: weird noise
    not sure how old they are but i kno there not factory the other owner had them replaced but not sure of how old they are
    also if u listen at the end of the video like the last second u can hear the noise go away
    May 2010
    1986 accord LXI
    Chicago Il
    Re: weird noise
    I dont kno how to take off belts
    is it a simple job?
    Nov 2010
    Jackson, Michigan
    Re: weird noise
    it could, and did on my buddys cutlass at first, then it made the noise all the time and evetually seized up. i don't know if this is your prob or not; but something to check. as for the belts, the main serpintine belt tensioner is on your altenator, loosen the bolts and the alt will slide foward enough to slip the belt off. the powersteering belt is taken off by loosening one bolt on the pump and it too will slide enough to remove the belt. its a simple job to do and you've got all sorts of help from people on here if you run into trouble. good luck with this, man
    Jan 2011
    89 accord DX
    omaha nebraska
    Re: weird noise
    sounds alot like the alternator i had take a dump on me. like snooz said the bearings could be bad but alternator could still be putting out good voltage
    mine died over the course of a week or so that i spent trying to diagnose it, finally let loose and seized up, was pretty easy to spot at that point lol
    May 2010
    1986 accord LXI
    Chicago Il
    Re: weird noise
    yeah i saw how to get the alt and ps belt off but how does the ac belt come off?
    i didnt see any tensioner on it or a place to slide it foward like the ps
    Nov 2010
    Jackson, Michigan
    Re: weird noise
    i'm guessing it does but someone else will have to chime in w/ that one. the previous owner of my car removed all that crap before i bought it
    Re: weird noise
    Your AC clutch is probably okay. Just leave the belt.
  1. weird noise
    By poison2003 in forum 3geez Accords
    Last Post: 02-02-2011, 10:15 AM
  2. Weird Noise
    By bank2me in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-23-2008, 08:56 AM
  3. weird noise
    By hondanutt in forum 3geez Accords
    Last Post: 08-27-2006, 10:18 AM
  4. weird noise
    By mattdx88 in forum Interior & Exterior Care
    Last Post: 08-19-2004, 07:41 PM
  5. weird noise
    By 89accordex in forum 3geez Accords
    Last Post: 01-13-2004, 05:45 PM
