Okay here I go I will be as precise as I possible can and be as detailed as possible. My car is a 1989 Honda accord LX-i 5 speed manual I got it from the previous owners who didn't drive it much in October of 2010. I knew the starter had its problems because it would click sometimes like a dead battery. The Car has about 169-170k on it and I Have recently put in new Plugs, Wires, Distributor cap/Rotor. The Battery's date on it is 01/2008 and The timing belt was done in 01/2005 less than 11k miles ago. Sometimes when I get out at night I can see a blit of smoke coming out of the head lamps and its smells kinda like burning rubber as if I did a burnout but not as strong or bad which I figure is wither a hose, Belt or the Clutch starting to go. But anyways onto the real problem.
So I replaced my starter about 2-3 weeks ago. Because All I was getting was a click sound like a dead battery no matter how many times I turned the key, So I took the starter out took it to advance and it was a bad starter so I bought a new one and replaced it and after replacing it I would get a weird start like it struggled to start and when turning the key the engine rpms would fluctuate madly like it just jumps and drop and wouldn't crank right away but started up in 3 secs or less(keep in mind it would do this every once in awhile with the old starter but mostly started up fine (like a normal car) or clicked a couple times like a dead battery).
So now today I replace my fuel filter I crank it to start it and it cranks like a normal car when the new filter was filling with gas and then it started to start and I let go and it didn't start so I turn the key again and it starts up the weird way then I make sure it wasn't leaking and shut it down.
40 minutes later I drive it from my house to the store and it starts normal then I get in it to come back home and it does the weird start 10 minutes later I go to crank it to go to the mall for some stuff and I hear the engine making a weird noise so i turned my music down and then I realize it isn't the engine its the starter not disengaging so I shut the car off and take the key out and it doesn't stop cranking so I ran inside for my tools and undid the negative terminal and it stops of course and I see a small poof of smoke which upset me
Then 20 minutes later I decide to visually look in the hood and not thinking I wanted to see what would happen if I put the negative cable back on and it sparks big and it starts cranking with no key in the ignition so I took it away from the terminal real quick.
Not the perfect car but it runs and hasn't given me problems since I've had it except for the starter actually and doing routine and required maintenance I love the car A LOT and want to keep it running and baby it as long as I possibly can, So what do you think?
